Terrio Handmade Knives, USA... aka, Knives don't lie !!
Feedback: +100 / =0 / -0
I RECENTLY PURCHASED THIS D2 KNIFE FROM THE ABOVE MAKER, TERRIO KNIVES. I was very lucky to find a "for sale thread" of some knives he had from shows or prototype ideals that he was moving and that were available for sale without his usual long wait. In fairness I like a knife with either an extended thumb rest or jimping. And I did ask if that was possible. Mr Terrio answered below in a Very professional and reasonable manner. I was after all getting a knife that otherwise would have taken months, if ever to have made. I also thought the "NOTCH" near the belly of the blade was maybe a bottle opener ??
See makers answer below, Great ideal, and this tells you a lot about the knife and it's maker.
Knife arrived very timely and the packing was overstated to say the least, very professional and safe for all involved. Clearly and boldly marked, leaving little room for error. Once I held the perfectly balanced, yet forward weighted knife I was amazed at 3 things ; the low cost, the high quality of materials and extreme attention to details. Examples: Handle of knife tapers to 4 almost 45 degree angles at each face, the rear pins could have been centered on the tang, but would not have been in line with the front pins. Answer ? Mr Terrio ground the back tins to a perfect 45 on one edge to mirror the scale and flow of the knife. I have never seen this, and I own hundreds of custom fixed blade knives as well as hundreds of production ones. Next, many Makers cheat by using the lanyard hole pin as the rear pin. But a lanyard hole pin does NOT provide the anchor power as a solid pin, thus this knife has both. Also the G-10 scales are crowned with added top texture and directional downward leading texture flowing to the spine of the blade, THUS and LOL, no need for blade jimping as the scale provides the traction and stopping grip. The G-10 lines is beyond tight and smooth at every curve. It is impossible to put or catch the sharpers object of finger nail any where on this knife. Paying this attention to sealing the scales eliminates water behind the liner and or scale. And what about that "Bottle Opener".
It is actually a waste point to collect and move any blood, shavings or file materials off the users hand. I set out to use the blade and after cutting 4 3inch caliper saplings of Sweet Gum, which are starting to Bud out here in the south had the blade covered in thick dark sap. The blade CUT the trees, no chopping was necessary, no beating my hands and wrist black and blue. The Thickness of the blade as well as the solid scale and liner resulted in very little vibration. And the weight allowed for very little effort. Next I completely removed the bark of the 4 sticks, 6 ft long each and removed a min of 7 side limbs from each , flush to the base. Turning the blade on edge a woodsman rasp was made. I finished the sticks with 90 degrees on both top and bottom. Then, and yes God forbid having my White Metal Detector in the Jeep, located 5 objects, all shot casings, by yes used the blade to unearth each at 4-6 inch depths, in good old Carolina Red Clay . A quick soap wash and towel dry and I prepared the evening steaks by trimming the fat and doing the same to 3 onions and bell peppers. Certainly not the toughest use, but the Blade still does as It did when received, Shave my arms.
Bottom point is I would certainly recommend, just on shear looks, and feel. But this knife is a real user and a EDC for sure. And the Price was too fair given the jobs it will do. I would suspect all of this makers knives are rock solid. I have never reviewed a knife anywhere and only do because this is a very special tool. I hope the maker does not mind the attention, but the knife deserves the attention, And honestly the sheath is equally amazing and value added.
D. General-Purpose in D2... $200 shipped SOLD, THANK YOU! shipped... pm with tracking number, and positive feedback inbound
Just a bit smaller, slimmer and lighter than a Growl, this GP knife is easy to carry and fun to use. 5/32" thick D2 tool steel @ 58Rc with a FFG gives it very good wear-resistance with an aggressive cutting edge. The spine is crisp for the first 2", gently crowned thereafter. Tapered 5" blade, 9.5" overall. Machine satin finish, full-thickness tang, textured black G10 scales with ruby red G10 liners. Handmade ambidextrous leather sheath.
Thanks for your interest and kind words!
I try to make my sheaths as durable as I can. They are all glued and hand-stitched, with full welts to keep the edge from wearing through the side.
The sharpening notch isn't meant to be used as a bottle opener, just to help catch anything that might slide down the blade toward your hand. I suppose you could open a beer with it if you really wanted to, but sooner or later that would dull the edge.
I very seldom put jimping or thumb treads on the spines of my blades. Unfortunately I am not accepting custom orders at this time.
Sometime this week I will be offering a basic drop-point hunter in Elmax and G10, and a couple of chef's knives in AEB-L. Other projects are always in the works, as well.
All the Best,
James
James is definitely one of the goods guys . If you knew his brother though, the viking owl , you may wonder :D
James is a great guy. I haven't owned one of his knives yet, but I did get a chance to check out one of his knives another member had purchased.
Very nicely done... One day I will own one of his knives, but my interests are in different areas at the moment. Congratulations on the new knife
Thanks for the review! I'm sure your new knife will continue to serve you well. :)
What James , no memories of the viking owl your brother " he's special " ? I miss him , oh well my friend I lost him also .
We had to put him somewhere he could get the help he needed. He was becoming a danger to himself and others...
may I inquire of the viking owl, hopefully he helped make the knife under review, lol.. Thanks James for making a great knife.
It's sort of an inside joke... I used to have an avatar of a goofy-looking owl with a Viking helmet photoshopped on it. :p
Great review. I'm really glad to see that knife being used and appreciated. When I first saw pics of it I fell in love and messaged James about it. I just knew it would be a winner.
thanks mack, I used it Sunday to trim down a treated 4x4 for a post I was making and yes, I did "tap" the back with a pcs. of 2x4 to get the rip started. sounds sinful but I brought it to use and it takes it. Has a very thick spine and did not bend or tweak a bit when I pulled down on it. great thing is I have yet to sharpen it, which is a big plus for me. Everyone who has seen the knife, likes the sheath almost better. It is made to last several lives. Now you got me wanting to order more. best money I've spent on a knife in a long time, stays in the kitchen, ready to go at all times. James makes the style anyone who likes the outdoors would enjoy. A true work knife. thanks again. Oh. and last, I enjoy the grip on the scales, never seen that done before.
I always love to hear from people actually using my knives! They're not collector's items, they're tools. :)
thanks mack, I used it Sunday to trim down a treated 4x4 for a post I was making and yes, I did "tap" the back with a pcs. of 2x4 to get the rip started... Oh. and last, I enjoy the grip on the scales, never seen that done before.
I have no problem with someone tapping the spine of the knife that way, to get it started in a cut. If you're holding the edge to the workpiece steadily and tap it in like that, you actually have less chance of making a poor strike and possibly chipping the edge. Just don't go pounding on it with a hammer or something, and if the blade gets stuck, tap it back out or better yet, drive a wooden wedge in behind it to relieve the pressure on the blade.
Most times when people break a knife, it's because they got it stuck in a piece of hard wood and kept hammering on it behind the guard area. That puts way too much leverage/stress on the blade, and sooner or later, something's going to snap :(
The grip on the scales was easy... the G10 comes from the factory with that "checkering" pattern already milled into it :D I get it from Alpha Knife Supply. I just build the handles normally, and the grippy texture is left intact on the flat sides.
O.K. then I get to ask this, I was very impressed with the 45 on the pins holding the scale, most would have flat lined them, but choosing to flow with the curve of the G10 added a custom look. Did you mean it to do that ? Stupid question, that and the sharpening notch on the blade imo make the knife jump out, and NO I DID NOT SAY JIMP OUT lol. D2 holds a better edge than I wrongly thought. The knife has made me rethink both steels and craftsmanship. Nothing I don't like about it. Plus the liner is spot on, and the balance is, well, I've said enough. thanks.
I always try to shape the bolts so they blend in with the rest of the handle as much as possible, and avoid any real sharp corners or edges on the handle. It's just more comfortable that way. It seems that comfortable handles usually end up looking nice, too.
One of the ways I test new designs is to carve/whittle through a 2x4 with them, and gouge/drill a hole through it. Not fast, or as a timed event like a chopping contest, but just to see how the edge and tip hold up, and to see if the handle hurts my hand. If a knife can do that without chipping, going dull or giving you hot-spots or blisters on your hand, it's a good knife in my book :)
I backed out of the ultranaut in favor of his Growl... usefulness factor.. and I'm glad I did. Ultranaut looks like more a collectable or "survival" type style.. the growl is a worker! great ergos, cheers!
edit: the growl = knife "B" in that picture.
