- Dec 3, 1999
I got one of Nathan's 9" discs--- It's a beautiful example of what a skilled craftsman can do.
I've been using variable speed, reversing disc sanders in the shop for quite a few years, so I have a pretty good familiarity with working on a 9" disc.
I put Nathan's disc on one of my variable speed/reversing Leeson motors, with the key he supplied, tightened the set screws, and hit the switch. OMG... it's even more of a work of art to see how beautifully it runs than it was just to admire how pretty and shiny it was when I took it out of the box. It spins SOOOO SMOOTH.... It runs perfectly!!!
Had this small fighter blade that had been ground down close to sharp with a 50X belt. (The clip already being ground and finished, is out of my normal sequence, but it doesn't matter for this post.)
Slapped some 120X Rhyno on Nathan's disc... I have better control with this disc than any I've ever used.
I wanted the plunges in this blade to have a little bigger radius--- I used my carbide guide and trued them up.
Went back to Nathan's disc. I used 1 sheet of 120 and 1 worn 220X ceramic disc- The new disc made pretty short work of this.
Hand sanding w/320x-
2 minutes later--- ALL 320X scratch pattern, running at an angle to the length of the blade. It looks a little funky, but it's just the photo, they're all 320X scratches.
Switched to 500x... and 4 minutes later had a dirty 500x foundation finish.
A good quality 9" disc is a GREAT tool to have... the quality level of Nathan's disc will be life changing.
:thumbup:
