- Dec 16, 2006
thats a bloody good idea for tinder mate!!!
I wonder if I can find any of that petroleum jelly in Australia?
The Sweedish firesteels are great, and pretty much the only ones that I buy. I have pretty much light all my fires with a firesteel, and have practiced on many, many types of tinders (I am talking natural tinders here. I carry stuff like this as well, but also want to know what I can do if that stuff is not available) and I have a bit of unsolicited advice.
Personally, I don't like the strikers that come with these. They leave deep gouges in the firesteel and you can throw an as good or better spark with hard square corner. I typically use the back of a knife. But, that is beside the point. My advice is for the manner in which you strike the firesteel.
If you do a scrap along the length of the firesteel, you will produce a bright and flashy shower of sparks. In my experience, this is what most people tend to do, and it works "okay." After a while, most people figure out that slow and a lot of pressure with the same motion works even better. The problem with both these methods is that after a time, you will realize your firesteel is getting thin in the middle and eventually it will prematurely break off.
Instead, I hold the firesteel in my hand, and really choke up on the thing. I put the striker within 1/2 to 1/4 inch from the end and do a hard pushing motion. Act like you are trying to take a chip out of the end of the firesteel. You will get two results from this 1) The spark not be a big shower, but be much more concentrated, and will burn hotter and longer. 2) With extended use, you just start to "sharpen" your firesteel to a point. You can continue this method for a long time and in time your firesteel will just become shorter and shorter. But, there will be no breaking and waste of the rod.
So, that is just my advice. Take it for what it is worth. I had planned on making a video of this technique, but had not got that far yet.
There was a contentious thread over there dealing with the origins of the firestraw idea. Whoever thought it up first, it is a cool way to carry little individual fire starters.
Once you've sealed one end and packed in the PJ-impregnated cotton (a small dowel helps), you might find it useful to clean the open end of the straw with a cotton swab (Q-tip). If you don't clean off the petroleum jelly a little bit, it's harder to get the second end to seal.
If you don't mind, I'll add a suggestion. After trying a pile of different ways, I've found it best to pack about 3/4 of the straw with the treated cotton, then stuff in some dry cotton at the end. This not only cleans any residue from the end of the straw before you seal it, but the dry cotton is easier for me to fluff so that it catches a spark. (Keeps your fingers cleaner, too!)
Great website link, BTW!:thumbup:
Guyon, thanks for the info on the sale at County Com.I ended up spending almost $100 over there.
Thought I might add just a little piece myself to make this a multi-purpouse device... If you use neosporin which is a petro based antibacteria product you will have a dual purpose product. If you need a fire great, or if you have an abrasion or cut also great!!
