I also agree with Stacy and Fitzo for both reasons respectively, they are on a nice balanced midline from two extremes. On one far side are folks who know very little about steel, knives or making knives but they have heard of Rockwell so they cling to for security and to show their prowess off to those who know even less than they do. On the other side of the range are the queen Gertrudes (the lady doth protest too much) who have a deep seated need to totally dismiss Rockwell hardness, this could very well be the result of not liking what the test said about their knives, or an inability to grasp a total understanding of the test.
A hardness tester is a tool quite a bit like a powerful piece of software is on your computer. When you first open it you can decide to throw away the manual and blindly plunk on a program that has a learning curve steeper than a cliff face, or you can make the effort to become truly proficient in its use. Most folks will only ever use one or two functions of that powerful software and many of those will most likely proclaim it as junk since it never worked for them; they tried using Photoshop when they only wanted to get as deep as a Windows paint program. Others will roll up their sleeves and get serious enough about the software to unlock its full potential for productivity.
The power of the Rockwell test is in giving you a precise reading about a very specific property, the fact that it does not tell you everything you need to know is its strength! As tools, tests that claim to tell you all or many things that you need to know in one shot are a lot like tarot cards, they work the best when they tell you exactly what you want to hear.
If you are working with equipment that allows you to give all of your blades the same heat treatment, test them, and then bump your temps up or down by 25F to test again, then the Rockwell tester can be a very powerful tool. If all you have is a torch and a bucket of oil, why do you want a state of the art oil filter wrench when all you have is a horse and buggy?? Not that there is anything wrong with a horse and buggy but the two dont go together, and the buggy driver has no business telling the formula one mechanic what he does or does not need for tools!
A Rockwell tester will only tell you what the penetrative hardness of a piece of steel is. It cant tell you anything about grain make up as in overheating things (in fact Rockwell numbers go up with overheated steel) or abrasion resistance. But it can be invaluable in fine tuning your heat treating process so that you can get the most out of it. People who feel that all they have to say about their knives is the Rockwell hardness just dont get it, but on the other hand those who are too quick to dismiss the test reveal an equal lack of understanding or insecurity. Tools are tools, it is how we use them that determines their value.
