bluerain, it sounds like you've designed it to perform bushcraft-type tasks, and I think you're testing it right.
I test that type of knife by first seeing if I can get it to shave hair off my leg (my arms have been bald for years
) and cut a piece of paper cleanly. Then I continue by whittling and batonning on wood (not metal) as described earlier. If it holds up to that and still shaves and cuts paper, you're definitely on the right track.
Now let's take it a step further and challenge the toughness...
Try lightly twisting the tip into a fresh 2x4, (the side not the cut end) just about any knife should handle this. Be careful, no need to try to ruin it.
Exactly! No need to flail away, just thump the tip into the pine and pop/twist out a few fibers. You can sort of feel if the knife does it cleanly and without bending too much. If the knife has passed the previous tests but snaps during this one, it may simply be too thin. Grind the tip back a little less acute on the edge.
Now dig a hole completely through the 2x4 with the tip. It's not a race, take your time; as you get deeper into the board you'll naturally be forced to take bigger chunks out. If the knife can do that without snapping, it's plenty tough and the geometry is good.
Now! Take that 2x4 and cut it in half
across the grain. No batonning. Chop and whittle. It's not a race, but work steadily without switching hands until you're done or give up. This isn't a performance test of the blade itself; if we've gotten this far we already have a pretty good idea it will stand up to hard work.
But if you can hack through a 2x4 with a 4-5" blade without getting hot-spots or blisters or cramping up, it means your handle design is good. That's important for a working knife, too
