- Aug 22, 2005
I have read through Mr Ankerson's very comprehensive list of edge retention testing. I work in a lab in which strain testing is done on various metals(many in their final shape) for the aerospace industry. The materials provided undergo a series of tests in which there is a minimum sample quantity to arrive at a statistically significant number. Basically, a diminishing sinusoidal wave(not really, but it is the closest thing I can give as a picture) is what many of these sample results end up looking like. I have seen hundreds of these results, the apparent result of which is that somewhere between 27 and 35 samples, the tests start to level off and a representative average value which is quite accurate appears. Of course the higher the number of samples the smaller the deviation. What does this mean? I am posing this as a suggestion for edge retention testing. If you wish to get an accurate testing result one or even two samples is simply not enough. At 10 samples the error is still large. At 20 samples we get closer and at 30 samples it is significant. I am not any kind of authority on testing, yet I feel that even though tests done provide a clue, without a larger sampling the tests are relatively insignificant. It is understandably difficult for a single individual to have large samplings due to time and cost, yet it would be necessary for accurate results.
Has anyone here performed catra or other edge testing on one type of steel to obtain a significant result? Is there any other standardized method of edge testing that others can perform to add to the results already obtained?
