how do you mean not fully?If you have 11 second or some other slow quench oil, 1095 likely won't harden in it, at least not fully, but 1084 will.
The higher carbon steel will give out different color sparks, right?You may be able to spark test if you have known 1084 and 1095.
Hmmm...not sure I understand. I use canola oil.If you have 11 second or some other slow quench oil, 1095 likely won't harden in it, at least not fully, but 1084 will.
even If the oil is warm?
I thought this forum hashed this 1095 issue out in Mar of this year.....?
or is it just the thin material is ok?
It will probably have brighter sparks. just compare the sparks from the unknown steel with those of the known steels and see what it's closer to. that is if you have known 1095 and 1084 on hand.The higher carbon steel will give out different color sparks, right?
