- Dec 3, 1999
Right out of the gate, I should mention that I am way behind in the shop... so this thread is NOT me volunteering to conduct and manage some kind of all encompassing testing for the forum. I'd be glad to share what I find, when I have time, but there's no timeline for this.
I have been learning about heat treating for about 14-15 years now, and it seems the longer I do it, the less I feel like I know/understand.
With the myriad of threads floating around all the forums about varying processes, it always leaves me wondering if what I'm doing is optimal, or if somewhere something could/should be improved.
So I'm going to be doing some more testing on a handful of steels--- definitely W2, 52100, and 1084, maybe a couple others.
Just an example of what I'm talking about here. I always do a very high initial normalizing cycle on these steels after forging them, 1700F to be exact. Most guys scream that's way too hot, and I'm blowing up the grain. Well, it is too hot for grain refinement, but for that initial heat, I'm looking to smooth out the disasters I caused inside the steel during forging, and start refining the grain on the next heat.
However, I've recently seen a lot of mention of heating to 1650 and quenching. I don't remember ever reading that in a text anywhere, and my gut tells me that it is throwing a ton of shock at steel that isn't ready for it... BUT, I've never tried it. So, I want to actually try it for myself and see what happens.
Another example, I have always done a spheroidal anneal on 52100 (well, since I got a kiln anyway), but I've seen some recipes for normalizing that are supposed to set up a pearlite structure that's easy to grind/drill, etc.
I'm going to be doing these tests with both my Paragon and my digitally controlled salt bath. I'm going to do some multiple quench pieces too, just because I can.
So my question-----
If you were going to do something like this, what would you try? What would you want to test? Any particular times, temps, quench cycles, etc.?????
At this point, my test "coupons" are in about 3 sizes-
1/8" X 1" X 4"
1/4" X 1-1/2" X 4"
5/16" X 1-1/2" X 4"
I cut a slice from each to do a Rockwell test in the "from the mill" condition. Since I forge most of my knives, most of my test coupons are forged down from larger stock, but I do have some pieces that were cut from the parent bar and surface ground in their "from the mill" condition.
So if you have any ideas about this, please feel free to throw them out there.
Thanks
So my question-----
1/8" X 1" X 4"
1/4" X 1-1/2" X 4"
5/16" X 1-1/2" X 4"
Thanks
