Briandt3
Platinum Member
- Dec 29, 2018
Hi all !
I wanted to share a few pics of work done by Josh at R.E.K.. Please excuse the poor photos, you'll have to trust it looks way better in person ! First the experience, from start, to finish, to follow up was top notch. The communication, knowledge, guidance and even billing could not have been better, Thanks Josh !
Work done by Josh on the TGLB: Remove the tube fasteners, regrind with a hollow grind, full satin finish to 220 grit, spine work and grind in small swedge ( close to a heavy chamfer ), edge set to 15 dps ( 600 grit and polished ) with a microbevel at 20 dps, reinstall nickel based
flared tubing fasteners. I also asked for his logo etched on the reverse of the Busse mark.
At the same time, I also sent Josh my HOG Gemini for a reprofiled V edge at 15 dps, 600 grit and polished. These blades are truly Razor sharp !
flared tubing fasteners. I also asked for his logo etched on the reverse of the Busse mark.At the same time, I also sent Josh my HOG Gemini for a reprofiled V edge at 15 dps, 600 grit and polished. These blades are truly Razor sharp !
