- Oct 22, 2001
Solstice said:Sooo you have to buy a Hell Razor to get BB to call you eh? Hmmmm, I'm thinking that alone would be worth it!![]()
Some of us don't have to buy anything.
Jerry Busse said:The grooves in the Hell Razor are concave at the bottom and slightly rounded at the high point, like corrugated sheet metal, and therefore act to stiffen the blade while at the same time lightening it and creating less contact friction between the bevel and cutting substrate. The long radiussed grooves do not introduce any major stress risers where as "scoring" a piece of steel introduces a major stress riser due to the angularity at the bottom of the cut.
In the early '80's a lot of makers were producing Rambo styled knives with saw back teeth along the spine. Our testing determined that those with sharp, angular cuts at the bottom of the tooth would consistently crack at the base of one of those angular cuts whereas those with radiussed cuts in the bottom of the saw teeth would distribute the stress over a wider area and showed no consistency to break along that same area. Angular cuts that are put into a knife, including those designed with sharp angles near the tang, prior to heat treat, are subject to micro fissures at the sharp corners of those angles.
As for twisting a Hell Razor until it breaks, the radiussed corrugations will again not introduce any major stress risers that would contribute to a higher incidence of this occurring. Add to that the power of INFI and you can be assured that this will NEVER happen under human induced stress. They always say, "Never say never". . but I'm pretty sure that we are okay here. You'd have to have a really long lever on a pipe wrench with the world's strongest vise coupled buy the strength of two gorillas in order to cause any significant damage.
As an experiment, try milling a radiussed groove in the steel that you normally score and then try breaking it. It will bend much further without breaking than an angular cut of the same depth.
Also, keep in mind the direction of our corrugations. Had we run the grooves from edge to spine, we would have made it much easier to bend by thinning the blade at the bottom of the grooves and giving the displaced steel on the inside of the bend a place to which it could retreat. This would still not introduce any major stress risers due to the radii at the bottom of the groove. In order to have this effect on the Hell Razor, you would need to fold it in half along its length, from the edge to the spine. Even if this were possible, which it is not, without the use of 100 ton presses and V-block dies, the only affect would be that it would bend easier without breaking.
Hope this helps,
(If not, just keep in mind that Im still on Pacific time at 6:45am and barely sober!!!!)
Jerry
Blammo said:Thanks Jerry. Thats the answer I was looking for !
I'll be ordering a knife from you.. Not the hell razor tho..![]()
Jerry Busse said:
Okay, I see how it is now. . . I make a quick run to the store to buy some more beer and during the short period of time that I'm gone, (about 4 weeks) Kassi starts puttin' the "word" out on me!!!. . . Thanks Pack Rat!! I owe you one!!! :thumbup:
Kassi, you best be puttin' on your "Holy Crap! I have to sweep the entire shop with a toothbrush?" shoes! . . . . . . Slave driver huh??? . . . . . Now you have to tell your kids that Mommy can't wait to see them again when she finally gets to take a break. . . .NEXT CHRISTMAS!!!!!!!![]()
Get back to work!!!!!!!![]()
INFInezer Scrooge. . . errrrr. . . I mean Jerry![]()
Blade Babe said:Oh crap! :foot:![]()
~Kassi~
Jerry Busse said:(snip)As for twisting a Hell Razor until it breaks, the radiussed corrugations will again not introduce any major stress risers that would contribute to a higher incidence of this occurring. Add to that the power of INFI and you can be assured that this will NEVER happen under human induced stress. They always say, "Never say never". . but I'm pretty sure that we are okay here. You'd have to have a really long lever on a pipe wrench with the world's strongest vise coupled buy the strength of two gorillas in order to cause any significant damage.(snip)
Hope this helps,
Jerry
Jerry. I just called the shop. You are M.I A.Jerry Busse said:Good dealio!:thumbup:
Jerry![]()
m10commander said:Jerry, I changed my phone number after I placed my Hell Razor order online would that be a problem? Thanks
