Landshark99
- Jan 19, 2007
For me they are a waste of time, use the right tool for the job, never had a lock failure using a knife the way it was intended to be used.
Maybe, this rake would blendYes, yes to all this, but …
Will it blend??!!
As “tests” they are waste of time, true, but the notion about using the right tool for the job is unrealistic, simply because there are elements of given environment that can always interfere w your right tool without your permission, whack the back of your blade, therefore unlocking it, without your control.For me they are a waste of time, use the right tool for the job, never had a lock failure using a knife the way it was intended to be used.
If use my folding knife to cut and slice, what it is intended for, what strange circumstance out of my control is going to happen, my house, my rv and my jeep are all full of tools. I try to always grab the right tool for the job. I do not want or need to use my folders as screw drivers, pry bars, chopping tool and for sure not batoning.As “tests” they are waste of time, true, but the notion about using the right tool for the job is unrealistic, simply because there are elements of given environment that can always interfere w your right tool without your permission, whack the back of your blade, therefore unlocking it, without your control.
If you look at the video, it’s pretty obvious why the two locks are disengaging and it’s not the locks flaw.Here is one of the more dramatic showings:
Don’t most people disengage the lock before batoning?If you look at the video, it’s pretty obvious why the two locks are disengaging and it’s not the locks flaw.
lame stuff, besides, nobody should be batoning all the way down, you start with the edge placed FLAT on the surface and continue with a wedge, not with f-ing folding knife…
Why? Are folding knives supposed to whack 2x4s with the spine of the blade? Is that what they’re designed for?If you are designing a knife and the lock disengages by hitting the spine on something it should be back to the drawing board.
Just because it didn’t happen to you, doesn’t mean you are right…what strange circumstance out of my control is going to happen, my house, my rv and my
not to go back and forth here but I would have been using a wire stripper instead of a knife, dropping any knife is rarely good for the knife. As i said before testing the knife for some rare event that is not in the world of how I plan to use it, just does not interest me.Just because it didn’t happen to you, doesn’t mean you are right…
‘I was stripping a small wire in my jet-ski when a metal cable under tension broke and bumped the knife out of my hand. It closed the blade. Here is your out of control circumstances, happening in your garage.
