I still want my CPMREX97.5MAX.......It's been stated abundantly here over the years, but heat treatment and edge geometry are FAR more consequential than simply touting the latest "greatest" CPMREX97.5MAX super steel.
But if enough people realized that, 4/5ths of the knife industry would have the rug pulled out from under it.
Way ahead of their time in my opinionI can tell you for sure that Rockstead did not miss the importance of edge geometry. This knife cuts better than anything I have ever seen.
Yes but I did not learn it until I came to this BladeForums.You'd think that this message would be abundantly clear by this point...
The comment wasn't directed at your post or your experience, but as commentary upon the general lack of awareness that the primary purpose of a "knife" is to "cut" well.Yes but I did not learn it until I came to this BladeForums.
Well, in fairness, there are several reputable companies that produce knives with excellent cutting geometry. And some very economical as well.We will end up using only opinels and Victorinox if this catches on
These companies make mean cutting machines...We will end up using only opinels and Victorinox if this catches on
As Larrin said, the correct geometry also depends on the proposed use for the knife.We will end up using only opinels and Victorinox if this catches on
Yes! I was just talking with Larrin about tougness testing different steels at different edge angles on Patreon a few days ago. No one else seems to want to do it.A short but important one I just saw on YouTube
The #1 Thing Most Knife Makers Still Miss
They try...As Larrin said, the correct geometry also depends on the proposed use for the knife.
A properly made heavy duty survival blade is unlikely to have the same geometry as a light duty EDC blade.
I agree.As Larrin said, the correct geometry also depends on the proposed use for the knife.
