- Jan 12, 2023
Awesome great job....
good good job bro! You can meet me in the comment section HahaThank you!
100% correct about the edge.good good job bro! You can meet me in the comment section Haha
This may be surprising, but if you had been hitting the pipe with the edge, it would likely have sustained less damage. The reason is, the edge is a symmetrical wedge and forces generated from chopping on either sides go against and cancel out! However, when the impact is applied to the spine, due to inevitable inaccuracy, the pressure on the contact area is not evenly distributed, thus more force would concentrate on one edge of the spine. And because the wedge of the 90 degree spine is not hitting perpendicularly to the pipe, generating asymmetric force, the spine would chip. The false edge sustained less damage because it took symmetric forces.
Rounding the spine does prevent the stress from building up, and BUSSE does this in house sometines for the exact same purpose. And that’s called NUCLEAR MELTDOWN!
Hello, thanks. Do you think the whole spine should be made round? Or is it enough to simply make the edges of the spine round (remove the chamfers)? Best regards, Vlad.good good job bro! You can meet me in the comment section Haha
I wouldn't worry about rounding the spine more. The knife is fine as is. I looked closer at the pictures of the damage on the spine and it's denting/smearing not chipping , however, more and more dents next to each starts causing small little sections to start breaking out. That's normal for the steel. IMO. You can whack that pipe for 6 months and that knife will not break.Hello, thanks. Do you think the whole spine should be made round? Or is it enough to simply make the edges of the spine round (remove the chamfers)? Best regards, Vlad.
I also thought at first that these were dents. But no, the steel was chipping in those places, one piece almost fell off and I broke it off with my fingernail (it’s on my palm in the photo). But I agree, even with these damages the knife did not break and no cracks appeared.I wouldn't worry about rounding the spine more. The knife is fine as is. I looked closer at the pictures of the damage on the spine and it's denting/smearing not chipping , however, more and more dents next to each starts causing small little sections to start breaking out. That's normal for the steel. IMO. You can whack that pipe for 6 months and that knife will not break.
Oh yeah! Your knives are the best I've ever owned and the strongest! I plan to buy 1 or 2 more in steel infi. Best regards, Vlad.Vlad22,
The beating you gave that Hell Razor made it a very happy blade!![]()
Nice!
Let's Drink!
Jerry
rounding the spine to a perfect half circle like Nuclear Meltdown would be optimal as it is perfoectly symmetric in any angle, but it is enormously time consumig without power tools. Just rounding the edges is enoughHello, thanks. Do you think the whole spine should be made round? Or is it enough to simply make the edges of the spine round (remove the chamfers)? Best regards, Vlad.
Hey boss! Salute!Vlad22,
Nice!
Let's Drink!
Jerry
Hi, I used files to round the edge of my badger attack. I spent about 3 hours... but I cut off about 2 millimeters for the rounding. I didn’t want to make a perfect circle so as not to remove a lot of metal from the sides of the knife.rounding the spine to a perfect half circle like Nuclear Meltdown would be optimal as it is perfoectly symmetric in any angle, but it is enormously time consumig without power tools. Just rounding the edges is enough
Please post the link !Hi all. I want to tell you about my tests. I did a test of a small busse (Barrel of Whiskey) and a badger attack of 2 generations. I cut 5 and 6.35 millimeter bolts with knives. The triggers of the knife were slightly damaged. The cutting edge is washed out. But the convergence of the knife is 5-6 times less than the thickness of the bolts. I also hit the knives with a 3 pound hammer. the knives held up. But I made the spines of the knives round. And now they don't take damage. the spine without rounding is damaged after contact with metal. I also made a new handle for Whiskey from G10. In Busse's attack of the badger, I changed the mount of the handle; after the impacts, the tubes that hold the handle became deformed and the handle linings shifted. I glued the handle to epoxy resin and secured it with bolts. the bolts are also with epoxy resin, now the handle has become much stronger. Maybe I'll add a video to YouTube. By the way, the mench had an Ontario knife. it broke under my weight. after that I broke his handle 4 more times from light blows from the side with a hammer. The 3.6-millimeter-thick Busse easily withstood this! but it was these bolts from Oniario that I used to recommend Busse. sorry for my shitty english.
