The 9 and Swabbie having a blast (and me too).
Since I got the 9 a couple of days ago, I've been aching to try it out. A while ago I won the Ka-Bar Swabbie in a contest and I took it along for the ride. I decided on giving both similar experiences and see how it turned out for me, the user. Mind you, I probably don't have the best technique, the best skillset or anything. I was just having some fun and the conclusion I draw here are personal. Nonetheless, I'd like to share them.
Here's both guys in their factory sheaths. It's striking how much larger the sheath of the Swabbie really is. I wouldn't like to carry that thing around for a long time. Not in a backpack (takes up a lot of space) or not on my belt (doesn't seem comfortable to have something like that on your leg for a long duration).
Next to each other it's clear that the Swabbie is a fair bit larger than the 9 too. Furthermore, the Swabbie is completely curved, no straight spots on the edge. The 9 is flat/saber ground whereas the Swabbie is FFG.
The difference in thickness is clear too. 9 on the left, Swabbie on the right.
When it comes to grip while using it, the 9 will be primarily gripped in one way: just grabbing the handle. Feels really good. The Swabbie allows for a variety of grips because the handle is so long. One finger over the guard, two fingers under, one under, full grip at the back of the handle, and so on and so on. More on the grips later on.
First up was some chopping. You can see the little treestump I was gonna chop. Don't know what it was. The diameter of the wood can be seen in comparison to the 9. I chopped both the 9 and Swabbie 20 times into the wood with almost no force. Wanted to let the blades do the talking. I can't seem to get any clear results out of it. Looks similar to me. After doing this test, I went ahead and finished the job.
Next up, batoning. Took two knotty pieces of a tree I can't find a translation of. We call it "Canadian poplar", litteraly translated.
These knots were quite easy. Both blades handles this very easily. I did feel more comfortable striking the 9 with my baton since the surface I could strike was flatter, whereas on the Swabbie that's exactly the area where the spine sweeps up into some kind of point before dropping down to the actual tip of the blade.
Wanted to try some finer tasks as well, so I tried making some Figure-4 traps. Started out with a long, straight piece of Common Hazel. Chopped it into bits and went ahead. I was able to get it done with both knives, although I would definitely prefer a smaller knife like a BK16 for this kind of job. The 9 was easier to work with than the Swabbie though. The guard of the Swabbie really got in the way while doing this task. I felt like I couldn't really control it.
I tried to make some fuzzies too, but my hands were aching a bit so I quit that rather quickly. It could be done, but again I'd recommend a shorter knife. Again, I had most difficulties with the Swabbie. Lack of control because of the guard, the rounded edge wasn't ideal either.
So, my dad came over and wanted to see what all the noise was about. He saw I was having a good time and said I could demolish the Hazel bush a bit further. It has to be removed in the future anyway. Work that's done now, we don't have to do anymore in the future. As you can see below, the 9 wasn't tired and handled the sapplings, smaller and medium sized branches really well.
Both knives after all of this...
First battle scars on my 9
That's the end of this photoseries. I hope you guys enjoyed it somewhat. In the end, I really came to prefer the 9 for a variety of reasons. Contrary to what I first thought, the Swabbie's handles are not that comfortable after all. I can't say anything wrong about the texture or the quality of the scales, but it's just the overall shape. Especially the guard and the extended butt start hurting your hand after a while. Don't like that a lot. The 9 is so comfortable you can keep going for quite a while without having painful hands. The Swabbie is just (again, for me) a tad too large and wide. It's cumbersome to use for a longer duration. The shape doesn't really accomodate batoning or woodwork. Do keep in mind however, that the Swabbie was totally not designed for splitting wood and chopping branches off of trees and bushes, unlike the 9. As far as a zombie killer, it would probably do great :D. The FFG of the Swabbie makes it a really good slicer, maybe a better slicer than the 9? I haven't tested that so I can't say. For a knife that's not designed to do the tasks I made it do, the Swabbie did perform above expectations. Very cool blade:thumbup:. During the tasks these knives went through, the 9 excelled though. I'm glad I put it through it's first paces and that it performed so well. I'm looking forward to using it more in the future.
Nice review! That looks like one of the lanyards that you got with it from granite, correct? I've been searching the threaded here and using my Google skills, but can't seem to find instructions on making that style of paracord lanyard. Most seem overly complex and not as functional, so I'd really like to make a few of those!
Thanks. That's indeed correct, it's one of 2 lanyards granite added to the package. I'd help you if I'd know how to make one, but I don't so I can't. Sorry about that. I can tell you though that the lanyard did make for an increased sense of control and security.
Thanks for the review. I recently bought a War Sword, and I feel the same way about the handle as you do: compared to my old Camillus BK9, they're not even close in comfort of use. As much as I'd love to have a Swabbie just for conversation starters, I can't justify the cost.
~Chris
~Chris
Thank you! About the handles: It somewhat surprised me because I really, REALLY like the texturing they did on the handle scales in the Zombie line. It makes them grippy yet not "tearing the flesh off your hands"-grippy. Too bad the rest of the handle just hurts like a mofo and doesn't allow for endured comfortable chopping.
Thanks for the props, Greg. Maybe I'll do a tutorial when I'm feeling better. In the meanwhile, look here:Lanyard knot for the knot to make the loop, and here:Celtic button knot for the two ends and the slider knot. Start with about 5-6 feet of cord so you'll have a little extra to make the slider knot, which is a Celtic button knot that you make separately (I usually gut the paracord for the slider knot) and put over the two tag ends before tightening. I adjust the loop so it's about 3" long, and then the two ends I get the knots so that I would have room to slide my hand in between them with a little more room for the sliding knot.
Hope that helps.
G-shark: Nice photos, Buddy! I had no idea the swabbie was so huge (and thick). I almost bought one of the Zombie knives before I decided on getting the 9 instead. Glad I did. Thanks for posting up the comparison, your hand looks about the same size as mine; always good to know how the different grips feel (even if it's subjective) over extended use. Sorry for the little thread-jacking above.
I keep assuming that the kabar zombie series knives are just a gimmick, but time and time again they seem to prove themselves. Maybe I'll eventually get one, but since they raised the prices I've chosen to just buy some beckers instead.
That entire line of zombieesque blades from kabar are a great value. I just don't think those handles would be very comfortable when actually in use.
Everytime I look at the handles on those ZK's my hand starts hurting. Really looks like hot spot city. I do love that cleaver though...
Great photos and reviews. I have been considering buying one of the zombie knives for a while now, just for fun, but I changed my mind and got a BK10 instead and I am glad I went with the Becker. I thought a zombie knife would look great in a display case, beaten up like a souvenir from World War Z, a nice battle trophy.
Hope that helps.
I don't mind at all, I'm glad to see some good info like this. Thanks for sharing. And yeah, you don't hear me complaining about winning that Swabbie because it's really neat. I'm sure it excels at what it's supposed to do, but I'm guessing I'll never have to test that:D. In practical everyday use around the house and "innawoods", the 9 overrules it. A lot. I thought it was a fun test since the steel factor is already out of the equation. Performance wise, the only things being compared is grind, thickness and ergonomics. Of course, the presence of someone with really good technique might give different results.
Thanks for the fun!!
You're welcome!
They definitely perform OK. They're using the same steel as Becker knives anyway so it can't be that. The price is somewhat up there indeed.
What do I always say? You can't not have a 9!
True, true.
Agreed, that's mostly it.
The scales are actually quite comfy. The steel around the handle isn't. Guard, butt,...
Thanks! That might be a cool idea indeed. After the coaring has worn off, or maybe stripped with a dark patina. Maybe some ideas for the future...
Great Pictures and I like the comparison. Never really checked out the swabbie in photos before. Interesting kife. Maybe a canvas for some mods? :rolleyes:
Great pictures, Shark! That Swabbie is the one the keeps "getting away" from me. It's on my must have list for this year, though, and the work you did with it proves that it's not just another zombie themed toy.
Excellent! It's nice to see the Swabbie getting a proper lashing and I'm glad to see the King is still on top.
Nice job and pics, way to break that 9 in :) The zombie knives don't really have any draw for me, but that zomstro that Murph/Todd customized is just beautiful..
Thanks! And yeah, I've thought about that. Grinding the top and bottom guard away, as well as the butt. Stripping, patina and the black handle scales... Could make it a completely different knife but I don't have the balls to do that. Yet.
It sure isn't just a toy. Same steel as the Beckers. Very sharp. And that point... you gotta watch out with that thing, damn. I'm afraid to lose an eye.
Sure is! The King is awesome, the Swabbie is not that far behind ;)
The 9 loved it! And yeah, a cool mod like that would be awesome. Skills and balls, they are lacking :D
Very nice comparison review thanks bud!!
You're welcome!
Yah I think that swabbie is would be absolutely killer with some mods... Take off the "talon" thingy on the butt of the handle, Grind the back guard down completely, and grind the bottom guard down a bit so its more comfortable to choke up on, then either stipple those scales, or give them a bit of some grip tape, and finally convex that edge out and it would probably make it 10X better! I think the swabbie is a very cool knife but it is hard for any blade to compete with the 9. It seems to chop better than all the other knives in its price range and probably beyond.
However, a really cool mod for that swabbie would be to make a D guard for it... How cool would that be?!
