glockman99
RIP Dann, you were a good guy.
- Jun 12, 2000
Originally posted by John Watson
Posted this before. Not very proud of my goofs. The injury is never as bad as the long wait at the emergency room.
First set of stitches from a knife that I can remember is when I was about 16 and was cutting some reeds with a POS folder. Just sharpened it and it got stuck in a knot, ya did just what you aren't suppose to do. Turned the knife around and cut toward the left hand. Sliced through the left thumb a bit below the nail almost cutting off the pad of that thumb. Several stitches later, back in business.
Got a few stitches when I jammed a 1/2 inch chisel through the side of my left index finger. Just the first of a few left index injuries.
Cut about a half inch off the tip of the left thumb tip cutting building stakes with a hatchet. No stitches, wasn't enough place to stitch. The DR just rapped it in elastic gauze and said good luck. I had luck and it reattached, no problem
Got a close call flicking open my AFCK. Wicked sharp. I flipped it open with my left hand and it got away from me. It was close to my face and when it made a turn it made a half inch jab in the side of my face just to the left of my mouth. Used a few butterfly bandages for a few days and really had no scar.
Got a new Accent and was cutting off one of those plastic bangs you get when you go to a boat show to go an come. Knife slipped, very sharp, and made a nice V cut in the side of my left index finger. Seven stitches later all is well.
Last incident, was the Saturday before Christmas. I was cutting up some raw turkey while doing some cooking. Using a long bladed Cold Steel filet knife and it needed a touch up. I had a set of long crock sticks in a red holder. NO brand name on it. The left stick slipped out of the holder and the single safety rod wasn't safe enough. A 1 1/4" cut right on the top of my left index finger down to the tendon. First thing I did was check to see if it moved. The doctor and I was supprised that I hadn't cut the tendon. He looked quite a while to make sure. Five stitches and it is the first cut that didn't heal well. When the stitches came out only half the cut had closed. Had to keep butterflys on it for seven more days.
My left hand should run in fear every time I take out a sharp implement.
...Damn, it's a GOOD THING that you don't play with chainsaws!.
