oh and its not bead blasted, its hand rubbed and polished.
i have a quicker way of cutting the lockbar also. i can use a regular end mill 3/8 radius and i vise the frame upright and simply drill down creating a half moon. i get cobalt bits for 8$ a pop at busybee. i find cobalt easier to use than carbide when working freehand.
and i have 6 of these knives on the go now i was talking about another one i was going to blast.
thanksguys. i have some ball end mills for future lockbar cutouts but will try the ones you suggested. also, the lock is stronger if the cutout is on the outside. this way the remaining ti is in line with the spot where it contacts the blade. the bar is less likely to fail if the pressure is straight back as opposed to tangential.
Hey, same mill here so I know what you mean. But say you're making the cutout the way you suggested, with the frame vertical, you take all your rough passes then go to clean it up with a final full depth finish pass which is 0.5" deep and you're only taking away 0.005 to 0.000 material, that's when it sometimes likes to chatter. Though I've never machined Ti yet, haha, so it might be completely different. HSS endmills seem to chatter the worst, carbide is usually better, depends on a lot of things I guess.
Yep that mill can pay for itself no problem, but keep in mind tooling gets expensive and there's quite a learning curve to be proficient at it. But it's fun! I taught myself CNC and so can you, the benefits truly are worth it.
