- Dec 5, 2005
Hi Nathan. I hope you (and Lorien) aren't tired of compliments on the LC.
never!
Nathan,
The logos and maker's mark on the FK look different, etched in finer detail than the previous version (on my EDC, for example). Just curious if you changed something up, or its my imagination.
Hi Nathan. I hope you (and Lorien) aren't tired of compliments on the LC. I received mine and love it. Very nice work!
My question is: is it stupid to heat up a LC with a hair dryer and put frog lube on it, and if not, would it be smart to remove the scales and put frog lube underneath them?
There is variation. The marks are all milled, which is pretty unusual. They are, nominally, about .003" deep. If a facemill is .0005" high or low and the engraving cutter is high or low they can be from .002-.004 in depth. Also, I hand grind the blades, including the flats, after heat treat which can reduce the relative depth. So, at the end of the day, there is variation. I figure as long as it's legible it's okay. *shrug* :thumbup:
Dear Mr. Carothers,
Do you think it's possible to make a Chinese Sword (Jian/Gim) with Delta 3V? Will you ever do a custom like that? It would be awesome if it had the flex properties of the Light Chopper.
Best Regards,
Ernie
Thank you Nathan. I am not a hunter / skinner of game but I use my user D3V EDC in eviscerating cardboard boxes. I tried to use the D3V in some limited capacity in the kitchen, but found out that it was not meant for that purpose, which it was never claimed to have been! How would you assess the use of your D2 version in such limited capacities? It may be deemed as an overkill for such gratuitous purpose, but I've never been famous for my sensibilities!
The blade are milled here, then heat treated, then hand ground after heat treat. This hand grinding is an importaint part of our process, but it's a bottleneck and would limit me to 400-500 knives per year. The only way to grow, without changing the product and process, was to hire some help, which we've done.
Nathan,
Thank you for your very detailed responses. This part of the process interests me. I assumed the hand grinding was done to the final edge only. If that is not the case what other part of the blade/handle needs refinement that cannot be obtained during the machining processes? Just curious.
Thanks,
Jim
The primary grinds are completed by hand to remove tool marks and convex the bevels.
This is the heat treat development and alloy I built my reputation on, and my D2 is very good.
We hired an experienced knifemaker, Mark, to work here in the shop. He is an accomplished blade grinder with a lot of experience doing grind work a far sight better than mine.
I'm curious to know how you feel regarding the differences between your 3V and your D2. Do you find one is a better slicing steel than the other, or one is better for chopping than the other?
