Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
D3V
Then, kindly ask You to help convince Nathan to make lots of DEK1, because DEK1 is the most popular model recently based on the sales time and occurrence "statistics".
At home I usually try to use a personal sized wood cutting board for eating meat, when using a good knife. Otherwise, and in restaurants, with my own knife, I will cut very close to the plate and pull the piece off. I did get a weird look from a chef once, when he was making the rounds and noticed I wasn’t using the standard issue very dull serrated knife. I think that he understood when he saw how cleanly my knife sliced through the meat.I’ve never used a good knife as a steak knife, because I feel like a weird and delicate aficionado, cutting food *just so* to keep the edge off the plate.
But I do like the idea of using one of these things for both skinning and eating. A beginning-to-end knife. I’ll still eat like a weirdo, but that’s okay. It won’t be the most awkward thing about Thanksgiving
Make it an option:Abby is very artistic
She has excellent taste and a beautiful soul. She could probably do a pretty good job picking out cool stuff for you.
Most babies I’ve ever known are pretty broke. All they do is eat, sleep and poop.Time to start hooking.
Nathan, were are the best corners to be picked up by babies with lots of money and low standards?
Asking for a friend.
I do the same at restaurants since I use my own knives. I keep meaning to buy some nice wooden plates for dinner at home, but I can't decide which ones and then I forget.At home I usually try to use a personal sized wood cutting board for eating meat, when using a good knife. Otherwise, and in restaurants, with my own knife, I will cut very close to the plate and pull the piece off. I did get a weird look from a chef once, when he was making the rounds and noticed I wasn’t using the standard issue very dull serrated knife. I think that he understood when he saw how cleanly my knife sliced through the meat.![]()
And by "some" you mean most.I keep a small white (soft) Arkansas Stone on the window seal next to the sink and stone my steak knife before I use it
I'll bet some people don't do that
I’m intrigued. I’ve always figured wooden plates and whatnot would be challenging to keep hygienic. Is that not the case?I do the same at restaurants since I use my own knives. I keep meaning to buy some nice wooden plates for dinner at home, but I can't decide which ones and then I forget.
Nathan me luv, I has a couple of few questions for you. Please enlighten me as I am a bit daft and slow:
- If I understand it correctly, all three steels options (T.D3V / MC / D2) will be offered for both the Signature Series and the Standard versions of the Skinner 2.0, correct?
- You will most likely be offering the Standard version in future Fridays' sales but the chances of scoring the SS version and the Steak Knives Set will be much less, correct?
- Lastly, why not consider offering the S.K. Set in a set of 2 instead of 4? IMHO, this is better marketing![]()
Hardwood cutting boards are porous, which allows microbes to remain in the board, but that porosity also absorbs moisture from the surface, depriving the microbes of water. So depending on the wood and the method of cleaning, it can actually be more hygenic than a plastic board. Bottom line: don't worry about it, just use what you like and clean it properly.I’m intrigued. I’ve always figured wooden plates and whatnot would be challenging to keep hygienic. Is that not the case?
And many types of wood have inherent antimicrobial properties.Hardwood cutting boards are porous, which allows microbes to remain in the board, but that porosity also absorbs moisture from the surface, depriving the microbes of water. So depending on the wood and the method of cleaning, it can actually be more hygenic than a plastic board. Bottom line: don't worry about it, just use what you like and clean it properly.
#notNathan Texturing will definitely hamper the ability to see the chatoyance. To really see the depth and shimmering effect the wood needs to be smooth and usually shows better with a polished glossy finish.Nathan, how will texture on the osage scales affect its chatoyance?
Absolutely.#notNathan Texturing will definitely hamper the ability to see the chatoyance. To really see the depth and shimmering effect the wood needs to be smooth and usually shows better with a polished glossy finish.
As much as I love seeing the chatoyance in woods like osage and koa, I really appreciate the texture on a hunting/skinning knife. Now on a steak knife ... it would look amazing.
Hey Nate, I posted a question yesterday, but it may have got lost in all the comments. Any chance of adding a “user grade” hollow skinner in D2 to the preorder menu? I was thinking micarta, kydex and tumbled (if possible.)
