Square_peg
- Feb 1, 2012
Theoretically, you could slosh some borax in the crack and stand the head in a coal fire, bring it to white heat, and hammer-weld the crack shut.
The axe-head is big and not very delicate- I'm thinking of doing this with my "new" p-v.
Forge welding flux is dry crystalline anhydrous (no water) borax that doesn't 'slosh'. It does however melt when you sprinkle it on a piece of orange-hot steel. At white heat you will begin to burn off the carbon in your steel. Bright yellow heat that starts to get a liquid appearance on the surface is the right heat for forge welding carbon steel.
To repair a crack in an axe I would grind the crack open and stick weld it.
