Excellent FAQ! Thanks..
The further up you go in the list, the longer the edge will last on your knife.
S30V
VG-10
154 CM
ATS34
440C
SANDVIK 13C26
8CR14MOV
8CR13MOV
AUS8
AUS6
AUS4
440A
Thanks...awesome info, I have saved that page !
I would modify that sequence somewhat.
Assuming good heat treat, I would list it as:
S30V
VG-10
154 CM, ATS34
440C
SANDVIK 13C26
8CR14MOV, 8CR13MOV, AUS8,
AUS6, 440A
AUS4
I found the edge retentions of steels I have placed on the same line to be so similar that I could not differentiate them by that performance characteristic when performing side-by-side cutting comparisons. I am unsure of the placement of the SANDVIK as I have never tested any.
I found that 440C clearly outperformed AUS8 and its Chinese cousins in edge retention in side-by-side comparisons cutting manila rope. All were hardened to 59 HRC.
I agree. 440C is highly underrated today and I find that I like it's 'toothy' edge.
Let's try something like
ZDP-189
S90V
S30V
VG-10
CPM154
ATS34
H1
154CM
SANDVIK 13C26
440C
AUS6, 440A
AUS4
:thumbup:
S90V should be above ZDP-189.
H1 should be above AUS8.
I guess I've just never found any use for it.![]()
i haven't found strider s30v any more difficult to sharpen than other s30v knives.
Well, I haven't owned any ZDP, so I just figured it was higher.Because H1 work hardens, doesn't that increase edge retention? I figured it was in the same 154CM/ATS-34 range....
440C is not right below ATS-34. It should be right above AUS-6.![]()
CRK hardens S30V a few points lower than typical. I've found soft steels (not specific work with S30V) to be hard to sharpen because of a persistent burr.In my experience the Strider S30V and the Spyderco S30V are easier to sharpen than the Sebbies - don't feel quite as hard especially in dealing with that wire edge.
Sandvik 13C26 is also better than 440C. That list is flawed.No way does AUS4 outperform 440A in terms of edgeholding.
