Hey Brad,
You started with one of the more complicated steels to Heat Treat, If you are going to go with CPM154 you will most likely be sending it out to be heat treated by one of the companies like Peter's Heat Treat or Bos. The "Wavy Line" you are referring to is called a Hamon and you can find all the info you could wish for in a search here on BF. You are correct on the Mosaic pins in that you do not hammer them they are epoxied in as well as the scales to the tang. I would not call them "Aesthetic" they add greatly to the shear strength and are extremely hard to remove if you have too. Hope this helps
