Fred.Rowe
- May 2, 2004
I took some pictures during the grinding process, to show the result of using the different bubbles on the jig.
I use three different bubbles. One gives me an approach angle of 11 degrees.
This is the angle between the belt surface and the blade blank.. I develop the cutting edge using this angle. Once I have the edge straight and true, I move up the blade blank using the 9 degree bubble. I am lessoning the angle, of approach, by two degrees, from 11 to 9. I grind at this angle till I intersect the edge that I produced with the 11 degree bubble. I then change to the 8 degree bubble reducing the angle of approach by one more degree. This moves the grind up the blade towards the spine. When the 8 degree grind intersects the edge, I remove the jig and use the now completely flat blade surface to finish the rough grind. I am now ready for heat treat.
If you have questions, don't hesitate too ask, Fred
