Paul Baleta
- Nov 26, 2018
Hi Folks
Another Bushmaster just finished...
The 'Bushmaster', a sturdy outdoor companion incorporating aspects of a bushcraft knife; robust construction, a comfortable handle with a full, tapered tang, a sharp spine for use with ferro rods, a spear point in line with the handle centre and a true convex scandi grind that has been hand finished. Here is the latest iteration of an older BALETA Handmade design with a few tweaks to bring it up to date and make it an even better Bushcraft tool.
This version is crafted in 26C3 carbon steel with a beautiful Hamon and stonewash finish on the flats. The blade has been differentially hardened. Below the Hamon line (the cutting edge) is about 63 HRC while above it is a lot softer - together with the scandi grind, this blade will be tough enough for any Bushcraft task. It has hard-wearing Micarta scales, fibre liners, a Loveless bolt up front, lanyard tube at the rear and comes in a custom fitted leather sheath with a dangler.
- Blade thickness: 4mm (0.16")
- Blade length: 120mm (4.7")
- Overall length: 235mm (9.25")
- Handle material: Jute Micarta with vulcanized fibre liners
- Fittings: Loveless bolt with brass pins and stainless steel lanyard tube
- Weight without sheath: 210g (7.4oz)
- Weight with sheath: 324g (11.4oz)
- Full, tapered tang with sharp 90 degree spine. Comes with a custom fitted sheath with dangler as seen.
€ SOLD
Also on my website: The 'Bushmaster' - Micarta with Hamon
Thanks for looking!
SPECIFICATIONS
- Blade: Uddeholm 26C3 carbon steel (HRC +/- 63 at the edge)- Blade thickness: 4mm (0.16")
€ SOLD
Thanks for looking!
