The Busse Combat Folder Has Become A Reality . . . And It Only Took 30 Years!!! . . . It Is Coming Friday, September 19, 2025 At 9:00 PM Eastern!!!
Jerry Busse
Moderator
The Busse Combat Ground Troop 35 (GT 35) Integral Folder makes its debut this Friday, September 19, 2025, at 9:00 PM Eastern.
These battlefield-ready folders are designed for those in harm's way, where every ounce counts!
The Busse Combat patent-pending BLOCK Lock, combined with its integral one-piece handle construction, makes the GT 35 the strongest, light-weight folding knife EVER made!!! The BLOCK Lock is NOT a crossbar lock!.
The handle of the GT 35 is machined from a solid billet of 6AL4V titanium. This gives the entire knife a weight of approximately 2.8 ounces!!!
The Busse BLOCK Lock surpasses the strength of every other folding knife of similar dimensions in this galaxy!
With a very thin-edged blade that measures approximately .010" prior to sharpening, the Ground Troop 35 is ready for deployment!!!
The first run of these magnificent folding knives will be marked on the spine of the handle with the word "Prototype".
These are true prototypes and therefore may vary slightly from the pictures.
If you are unable to handle slight changes, then I recommend that you wait to purchase it from a future run.
Admittedly, the price may be higher on future runs and it will certainly not be as rare as these prototypes.
This first run of prototypes will consist of orders taken within the ten days allotted for this run.
Orders will be shipped in the order in which they are received. So, the sooner you order, the sooner you will receive your knife.
Why did we use BC AEB-L for the blade material?
Combine our heat-treat protocol with a steel that is already known for its toughness and excellent stain resistance and it is the logical choice for this project.
Ground Troop 35 Specs:
Open Length: Approx. 8.2"
Closed Length: Approx. 4.7"
Lock Type: BLOCK Lock
Weight: Approx 2.8 ounces
User: Right Hand, Left Hand
Blade Length: Approx. 3.5"
Handle Length: Approx. 4.7"
Handle Thickness: Approx. .250" (1/4")
Blade Width: Approx. .96"
Blade Thickness: Approx. .090"
Blade Style: Drop Point
Blade Bevel: Flat Sabre
Blade Steel: BC AEB-L
Blade Finish: Hand Applied Satin
Opener: Thumb Stud or optional Thumb Hole:
Pivot Type: Ball Bearings
Pocket Clip: Tip-Up
Pocket Clip Material: 6AL4V Titanium
Knife Type: Manual
Handle Material: 6AL4V Titanium
GT 35 Prototype Pricing:
$597.00
GT 35 In The Opened Position
GT 35 In The Closed Position
Prototype Logo
Handle Thickness
Recall the first mention of this at a SOF conference in Las vegas... The first run are to all be "prototypes?"
