Sanrenmu, Navy, Bee, or Ganja are your best bet for 20ish axis/arc lock types
I wouldnt go that route because while you are getting a SIMILAR product it is still a cheap knock-off.
I second the Sanrenmu, specifically the GB-763.I'm pretty sure the cheapest ones you'll find are the ones made by Sanrenmu
well these companies did work for benchmade, kershaw and other major us companies for the chinese imports so i suppose if benchmade ever had a redclass with the axis lock it would be the same
Fact is they don't have the big name quality control. I'd recommend a mini grip over a Sanremu anyday and I really dislike the grip series. The Benchmade Ambush is a really good suggestion.
That would be interesting if you had proof. It would probably change a few people's minds, of course it would have to be actual proof not assumptions put together with deductions like;
" Well there are only three knife manufacturers in China, so since the big three wouldn't all use the same one, then these must be the same manufacturers. "
Actually, if you search on BladeForums, I believe you'll find a few very thorough discussions on Sanrenmu with acknowledgements from qualified sources that Sanrenmu has made knives for some big US companies, like Spyderco, CRKT, etc... (even Benchmade?).That would be interesting if you had proof. It would probably change a few people's minds, of course it would have to be actual proof not assumptions
No one's claimed Sanrenmu uses 154CM,...For instance, I'm skeptical that this Sanrenmu (whatever it's called) uses steel that's the same caliber as Benchmade's 154CM.
I believe some have.If they really believed that Chinese production was equal to US production, they would rush to push all manufacturing to China.
Now, that's just ignorance talking.But I suspect they're secretly aware, although unable to say publicly, that they know what is common sense to the rest of us: on average, the quality of work performed by a nation with worker's rights as opposed to quasi-slave labor produces a better product.
Thought the OP was interested in the cheapest axis-type knives. Btw, the Sanrenmu 763 (an axis-type knife) can be purchased at about half the price of the Storm (which isn't an axis).Take the Kershaw Storm. for instance. Good materials and quality, with a big name designer behind it, produced in the US for around $30.
But, I thought you said it was "common sense" that quality would be lower from China. That is what you said and/or implied ("common sense to the rest of us: on average, the quality of work performed by a nation with worker's rights as opposed to quasi-slave labor produces a better product.").Do I know, for a fact, that a Chinese manufacturer is producing knives of lower quality? No, I can't say that I do--but I can say the odds are quite high that it isn't comparable to an in-house Benchmade.
