The CRKT Ripple: Why I Didn't Buy It
Personally, it's a bit small for me, but 66 bucks isn't bad IMO. I mean, it's got to be a bitch to make a production folder with IKBS. And IKBS isn't Onion's. It's knife makers Flavio Ikoma and the team of knife makers at Korth Cutlery. Which is what it stands for. I.koma K.orth B.earing S.ystem.
Greetings: I have been carrying a ripple for about three weeks. The following is based solely upon the ONE Ripple I own. My overall impression of the knife has changed slightly since the time of purchase. The IKBS is VERY smooth. Unlike many other blade pivots this one was exceptionally smooth and liquid from the first. It has neither improved or degraded after frequent cycling. I expected it to change. It did not. I expected some small degree of blade play to develop after MANY opening and closings. No perceptible vertical or lateral blade play yet. I was prepared to deal with a comparatively soft blade steel when touching up the edge on a Sharpmaker. Nope. It feels as hard as a good 440c. The overall construction is somewhat of a contradiction. As with many Ken Onion designs this is a slim and sleek knife. My initial impression was that this is a lite duty gentleman's folder. Thin frame, multiple holes as part of the design elements, rounded blade spine, thin blade, thin locking bar and open frame contribute to this visual delicacy. The steel frame's weight and relative mass make the knife feel heavy for it's size and therefore feel quite solid.
Now the down side. The thin dementions are not conducive to extended periods of use. There are many "hot spots" easily felt after even a short cutting session. The frame machining is RIFE with sharp edges. Not only the outer edges of the frame itself but the slab sides. The raised areas of machined longitudinal curves and recesses are sharp. The areas surrounding the slab screw head recesses are really sharp. The serrations on the stainless pocket clip, which mirror the blade thumb jimping, are also sharp. These seem to be more a result of the manufacturing process than an intended functional attribute. The holes through the clip (used to mount it to the frame) are oversize and eccentric resulting in the clip shifting side to side in use. The IKBS ball bearings are packed in a brown/tan grease of medium viscosity. Clip-less pocket carry seems to result in dust, lint, grit, and other exotic material accumulating AROUND ~ but not IN the bearing area. The residual grease visually appears to keep it from contacting the ball bearing themselves. The blade itself was not sharp from the factory. All considered I'm still pleased, even though I paid almost full retail because it is a new and unique design. Due to the IKBS and a thin lock bar with an almost flat contact between lock face and blade tang, the knife is impressively smooth to open and close. Lock up is at about 50 percent with no play or creep. Stoning the multiple offending edges with a fine ceramic hone removed their sharpness. Some work on the Sharpmaker rods produced a sharp blade edge. Two shims on the clip screws encourage carrying it out of the bottom of my pocket lit pit. It will not replace my EDC but it is fun to play with and an interesting addition to my limited collection. OldDude1
The clip on the one I handled is rock solid no movement at all and there are no sharp spots some rough (jimping) and some acute angles but not sharp.
I do agree with you that the slim design of this could make prolonged hard use of this knife without gloves a hand blistering experience.
I have a Ripple on the way. I for one appreciate CRKT for bringing higher priced designs down within the reach of those of us that may not have as large of knife budgets. I would love to own a Begg to experience the IKBS, but could never afford it. Now I can have an idea of what it would be like. Are CRKT's my favorite, no, but I never shut the door on them because they work with soooo many knife designers and makers that produce knives that I would love to own. Ken Onion, Greg Lightfoot, Carson, and on and on. I have an M-21 that has been beat up and sharpened so many times that it is starting to look like an M-16. I have an Urban Shark that is almost officially dead. CRKT knives need a little more tlc to keep them runnin, but when I am at work, I do not blink when it calls for a little abuse. My after work carries are Spydies, Kershaws and more. My hats off to CRKT for being creative. There are many choices in their catalog that scream differences. Most do nothing for me, but there is alot of verity. There are a few companies this year, that have really gotten bland in their line-ups. Not to mention names, but their knives just seem to have lost their flavor. As of now, CRKT and Spyderco will be on my 2010 buy list. Just my 2 cents.
Love the look of the knife and how thin it is. I don't think I've ever owned a CRKT, but I'll be ordering one of these soon.
