Okay, just finished heat treating a sample of RWL-34 using one of Damasteel's HT examples.
The example I followed is as follows and mimics the number IV HT example found at
http://www.ssdamascus.com/technical.html :
Test piece is RWL-34, 3/4" X 1 1/2" X 0.138"
(I foil wraped the test piece and placed it in the cool oven)
Equalize (not specified by their example): ramp to 1410 F. / soak 7 min.
Austenitize: Ramp to 1980 F. / soak 12 1/2 min.
Rapid air quench to handling temp.
Still air cool to room temp.
Single Temper: 350 F. / 2 hr. 10 min.
Deep cryo (< -300 F.): 15 min.
Rockwell: 62 HRc
Their example for this HT (their example # IV) proclaims a Rockwell of 63 HRc for RWL-34.
I hope someone checks the Damasteel specs. to see if I understand them correctly
http://www.ssdamascus.com/technical.html . I tried to understand them the best I could. From all I could determine they are calling for a cryo of only 15 minutes and only after a temper and that they specify only a single temper. Later on they explain a HT for their damascus and it shows some different specs for that.
With all that there are three things about this HT example I would be reluctant to do for a real blade of high alloy stainless such as this: temper before cryo, temper below 400 F. and cryo for such a short period.
Two things in closing: I will be scoring and breaking the two samples and plan to post a link to pictures of the halves break surfaces, and I noticed that Rockwell testing showed that the last example (this one) seemed more consistant in hardness as Rockwell testing progressed. The first HT example, while predominately tested 62 HRc, tested a couple times at 61 HRc out of about 7 or 8 testings. All five Rockwell tests of this latest test piece consistantly read 62. As I stand now and without knowing more than I do yet I would guess that the shorter soak time at austenitizing may be responsible for the higher degree of consistancy. However, and I hope not, it could be the temper before cryo.
RL
