- Aug 18, 2013
What happened to your 561? What specifically about the steel liner and blade design compromises its ruggedness? Also it should have ball bearings and not washers at the pivot.
The steel liner is to thin compared to the other side. One side is really rugged, but this doesn't matter all that much as the other side is really weak. In my experience the steel side liner bent a little in use, making the pivot miss aligned and causing weird blade play. The ball bearings got full of sand and mud and didn't function that well after that. I also dislike how the handle gets wider at the bottom then it is at the top, this forces you into a grip where your index finger is tightly holding onto the knife, so if your doing any kind of whacking with the knife you get hotspots quick. I messed up the knife trying to cut a flat side onto a branch so i could dig into a creek bed with it as i needed some water bad. The ball bearings are like air suspension on a cadillac, its cool when it works and makes the ride feel smoother but its not necessary to the cars overall function, and when it fails it fails in a big way. The blade also thins out too quickly in my opinion for rugged use, this is a problem if I'm trying to baton some wood or strip some bark. Someone could easily say "you shouldn't be using a folder for that, the knifes not built up for that level of use you should take a fixed blade". As i side i like to do minimalist hiking and I've found a folder that can hold up to all these things and its made by Emerson. My main problem with carrying a fixed blade is one time i was out hiking and i decided to go into town and get some supplies. Than the cops pulled up and started harassing me over my knife, then they took me down to the station and gave me a delousing well they all made jokes. Then i had a flash back and snapped, beat them up and escaped on a dirt bike.
