- Nov 25, 1999
Dave,
I can take the challenge. Please select angle-forcing sharpening system what do you like and I will work freehand using 8 double-sided DMT Duo-Sharp plate for reprofiling and the set of SPYDERCO ProFiles for finishing. I have no experience with EdgePro, but looking onto its pictures I cant exclude that I could finish my work before you would set up this super-system
Seriously, to keep this Forum as discussion place but not as praising and hyping forum it would be sensible to compare comparable things with a small bit cooler head than first delight suggests.
I know clearly Sharpmakers limitations, here they are:
How EdgePro holds up in these matters? This would be fair comparison!
Your money are in trouble, Buddy!If you took two 10" cooks knives that were totally dull and set a challenge to two people using the Sharpmaker and the Edge Pro I know which person I'd have money on!
- It tends to round blade tips if working on rod edges without suitable care. Working with care it is pretty difficult to work with very last some millimeters of edge near the tip.
- It forces you to reprofile your edge if factory sharpening angle doesnt match preset angles. However this drawback is characteristic to each angle-forcing sharpener excluding ones with smoothly adjustable angle.
- With standard set it is fairly slow when reprofiling.
I have much better idea: set it up constantly in your kitchen. Some strokes on fine rods after each serious knife use would prevent you from using EdgePro on your kitchen knives for long, long time, if not at allMy Sharpmaker will now be sold secondhand or it will stay in the garage.
