Elitism based on what my definition of "gentleman" is compared to the apparent knife industry definition.
I don't own the DD, but I do the Opinel #8. It is a great knife, and probably the best I own for slicing because of the full (or is it flat?) grind, and it gets very sharp. Here are a couple things I don't like about it that you might want to consider.
#1 It is hard to open. A lot of other people say this, and it is true. I have found it impossible to open with one hand, which means you have to set down whatever you are working on to just get it open. It is equally hard to close. And no, it doesn't get much better with use.
#2 It is uncomfortable in your pocket. To tell the truth, this is the worse of the two problems in my opinion. The handle of the opinel is rather thick, compared to just about any other pocket knife. Because it is lacking a pocket clip, it settles to the bottom of your pocket, and is simply uncomfortable. And I am not one to complain about stuff in my pockets. Don't get me wrong, the thicker handle fills your hand really nice, but in my mind it is just too thick for an EDC. At the end of the day the Leatherman ends up in my pocket.
So, would I buy it again, yes. But it won't be in my pocket every day. I haven't tried the Douk-Douk, but its thinner profile sounds really nice.
if you happen to be a perfect gentleman
At the price point, get both, carry and decide which you prefer?
You can loosen the pivot of the Opinel by putting a large screwdriver in the slot and twisting the inner ring apart. Go slow.
You can prevent the wood from swelling tight when wet by melting beeswax in the joint.
You can join the deep French tradition of modifying your Opinel handle. Use a sanding block to flatten the sides and carry it pivot up for better pocket carry. Will end up carrying as well or better than a Sodbuster, IMO.
If this sounds like a lot work, it is. An Opinel is a starter kit for a great knife. Without the work, they are much less great.
His second paragraph of substance was literally " money is very tight at present and I cannot buy both "
They're both roughly $25 knives, + shipping
If one is in a position where the absolutely can't spent $55, but can spend $35 on one knife, my suggestion is wait one paycheck, find $20 more, be it one less beer every day till payday, or leftovers instead of pizza on Friday, and buy both.
Yea, i know you can modify it. I just haven't felt like putting the work into it. The handle on mine hasn't swollen, it is the same as it was when I got it. I hadn't heard of the screwdriver trick, I might have to try that.
Also, does someone good with leather could probably make a nice pouch for it to go on a belt, like a Swiss army knife. That sounds like a much better way to carry it. I am NOT good with leather so I havnet tried. Maybe duct tape? :-D
You assume (incorrectly) that I'm American and my lifestyle is similar to yours.
Regardless, I didn't post this thread to start an argument over semantics. I received the answer I sought and I'm happy with that. Good day to you all!
Let us know what you end up with and how you like it.
Can you devellop? Never heard of that...Both are squarely in the realm of working class knives.
The douk douk has the darker backstory. The knife still has a stigma in some circles due to the ignoble use it saw in the french algerian war.
Murder. Mutilation. Torture. All the stuff that goes along with a brutal civil war.
The douk douk was affordable, available, would hold a razor edge, and easily concealable.
One tactic was to hammer the handle scales together to create a field expedient fixed blade.
The use was wide spread enough that it became symbolic of the conflict. Comparable to the machetes of the rwandan genocide.
