The ideal survival knife
Alot of you already mentioned things I think the ideal survival knife should have, which is to be expected with all the fine knifemakers here, I'll repeat them anyway though to describe my complete package.
I'd start out with a boloesque shape, good for chopping, with a thin flat grind near the handle for fine tasks turning into a convex by the time it gets to the recurved chopping area. I'd probably then clip the point a little bit since the bolo point isn't very good for thrusting. The spine near the handle should be square and sharp for flint, and round on the half with the point for batoning. A non-elastic lanyard properly fitted to be used as a guard when thrusting in addition to wrist use for chopping. A large flat pommel for use as a hammer head, maybe a can-opener as a choil (a bit gimmicky, but hey). Stabalized non-brittle handle material, there's enough good ones that there's no need to pick "the best". Diamond hone built into the sheath somewhere, and a pocket for other survival goodies. Steel more in the tough range and differentially hardened or tempered for strength.
I'm sure I'll think of some other stuff later, but this is the best I can come up with at the moment.
edit: Yup, thought of something else, cordwrapped handle with a quality climbing cord. Having a length of strong rope can be invaluable. The kevlar ropes can be surprisingly thin for it's strength, thinner then alot of shoelaces.
my personal choice is a design I've had flooting around in my head for a while and haven't gotten around to making yet. 6-7" blade of differentaily hardened L-6 or 5160, spear point slightly recurved blade 2" wide at widest, full convex grind and a 1/4" thick at ricasso with distal tapper to the point. Bronze or steel gaurd, hidden tange construction with sandblasted linnen or canvas mycarta, steel pommel silver brazed to a nut and a split bolt silver brazed to the tang, everything cinched up tight and secured with acureglass epoxy, only sharp edge would be the cutting edge, no notch at ricasso, nothing to snag or catch, slightly pistol shaped grip for retention in the hand. And etched finish or black coating to cut down glare and as a corosion/scratch preventer.
The sheath, 9-10 once waxed leather with multiple eyelets to facilitate carring in differant set-ups rigging, and a small pouch on the front for a diamond stone and other odds and ends.
Think Kabar on steroids :D
peter nap said:
George, I'm trying to get everyones concept of the ideal survival knife. I know yores would need to be capable of spreading relish... :footinmou :D :footinmou :D :D :D
Everyone, please include the tasks you expect it ti preform. Everyone's different. Not all people fall out of trees! :o
Don, if a knife can surive my relish it will be one heel of a good survival knife. :D ;)
