Steve- To tell you the truth, I'm sick of lamb! But fortunately, the next door neighbor's Lab has developed quite a fondness for it
Will- My mom thought that 'No me chingas...' saying was absolutely hilarious. I'll have to tell her that you didn't make it up and how it came about.
Jerry- You're more than welcome, My Friend. Its always an honor and a joy for me to work with you.
Personally, I thought that the coconut test went
extremely well. I never expected that the Duelist would split a coconut like a machete- that's just not what it was designed to do. But, the results clearly show how devastating strikes to the head can be with a good bowie.
There is no question that the spine of the blade, which flares out abruptly from the deep hollow grind behind the edge, acts as a brake. You and I have experienced this phenomenon before with your fighting blades when I've cut other wide dense targets such as boards or plywood. It
would be very interesting to see what rounding the hollow grind/spine transition buys us. I've never asked you to do this because I knew how much it would shock your delicate artist's sensitivities
From the point of view of a knifefighter, however, the above would be purely icing on the cake. the Duelist and your other fighting blades are highly evolved to cut flesh and bone, not coconuts or trees or sheets of 3/4" exterior grade plywood. The very reason for putting such a deep hollow grind behind the edge is to 1. decrease the overall weight of the knife as much as possible while still maintaining ideal balance and momentum, and 2. to minimize friction as the blade moves through the sticky, clingy, sucking medium that is flesh. And your hollow grind accomplishes these goals to a faretheewell. Your blades move through a leg of lamb or a shank of beef like its not even there. No flat ground or convex ground blade that I have tested can do that- they simply have more blade material behind the edge, contacting the meat, and slowing the blade.
I can't wait to see everyone at Blade 2002. Its gonna be a great time
Mario
