I think a scandi grind is fantastic for bushcraft type tasks, especially those including woodwork (which are the majority in bushcrafting). Getting away from woodwork, however, I think the scandi leaves a bit to be desired - not in terms of ability, but in terms of longevity. As an example, I used my Enzo Tracker to punch a hole in an Altoids tin so I could make some char cloth, and to open up the hole a bit, I twisted the blade. The edge near the tip was so fragile that it immediately deformed. It wasn't catastrophic or anything, but it took some time to get it right again - all for a task that was fairly basic in terms of a utility knife. A knife with a more utility-based grind would have performed just as well at this task, and would have had no edge deformation.
So basically, I think scandi grinds are fantastic for those tasks in which they are designed to be used, and flawed in those tasks in which they are not. Nothing ground-breaking here - goes back to the old viewpoint of having the correct tool for the job at hand.
In a situation where the blade in hand is the only one available, I find the scandi grind lacking. Sure, it does wonders on wood, but the same tasks can be achieved with a more durable grind and a little more effort or better technique, and you don't have to worry about being careful with the edge while performing tasks other than cutting and slicing.
Just my own 2 cents... hope it helps!
