The 'Meerkat' Hunter - Green Canvas Micarta
Feedback: +10 / =0 / -0
Hi Folks
I have just finished up a few more 'Meerkats' in time for Christmas. Here is the first...
Introducing the "Meerkat" - a compact, lightweight every day carry or utility knife.
It can be worn as a neck knife, but it's particularly suited to be worn as an appendix or scout-carry inside the belt. The Kydex sheath holds the knife firmly and the belt clip is reversible for left-hand or right-hand use. This makes out of the way for active body movement but also fast and easy to deploy with one hand.
The blade is big enough for most everyday tasks and has a Drop-Point profile which really works well as a hunting blade. The handle is long enough (fourth/little finger curls around the butt) to get good leverage on the blade but also thick enough that you can get a firm grip and be able to use it for a length of time without cramping up. The jimping also helps you get a real positive grip on this little big blade, especially in wet situations. At the front is a Corby bolt to ensure the handle scales will remain attached for your lifetime. A lanyard tube at the rear adds practically.
Tucked into your belt or backpack, it is small and light enough that you won't even notice it's there... but has the ergonomics and is big enough for just about any outdoor task. It won't chop down trees or split logs... but will do everything else!
SPECIFICATIONS
Blade: Bohler N690 (+/- 61 HRC)
Blade thickness: 2.6mm (0.1")
Blade depth: 30mm (1.18")
Blade length: 71mm (2.8")
Overall length: 153mm (6.1")
Handle material: Green Canvas Micarta with vulcanized fibre liners
Fittings: Brass Corby bolt and lanyard tube
Weight: 92g (3.2oz)
Weight with sheath: 136g (4.8oz)
260 Euro
Also in my webshop with a few more pics: The 'Meerkat' Hunter - Green Canvas Micarta
Thanks for looking!
Paul
Very slick rig. Beautiful blade and great sheath/clip setup. If I make something suspiciously like this in the future, well, I'm old enough to claim I thought it was my idea all along. In all seriousness now, i truly mean it, all except the ' my idea' part.
