American scientists have used metric from about 1850 !! But since few learn science in school here we still have English. Of course we solved the argument by making cars with both metric and English !
The other helpful one to keep in mind is that an inch is about two and one-half centimeters.
A kilogram is about two and one-quarter pounds.
One cup is about a quarter of a liter.
A change of one degree-Celsius in a change of almost two degrees-Fahrenheit. Because degrees Celsius are much larger, fractional degrees are used more often when temperatures are expressed in Celsius. In the US, for example, it is rare to see ambient temperatures expressed in anything but integers. The sign at the bank will tell you that the outdoor temperature is 86 or 87, but never 86.5. Degrees Fahrenheit are small enough that we don't need to split them. The average person can't feel the difference between 86 and 87, much less 86 and 86.5. But the difference between 30 and 31 degrees-Celsius is almost the difference between 86 and 88 degree-Fahrenheit which is a definitely-palpable difference and so at least half-degrees-Celsius are needed.
In addition to knowing that water freezes at 0C and boils at 100C, it is handy to keep in mind that comfortable room temperature (about 70F) is about 21C. A warm day (86F) is 30C (again, 16 degrees of Fahrenheit change, 70 to 86F, caused only nine degrees of Celsius change, 21 to 30C). And normal body temperature is exactly 37C. From these few reference points and using the two-to-one approximation, you can get a good "feel" for practical temperatures in Celsius.
I suppose having to add 5/32" + 3/4" + 5/8" + 1 3/8" + 15/16" + 1' 8" would tax any man, as well as his $5 electronic calculator. Luckily metric can be entirely done in your head.
What is metric for a pinch of salt and a dash of pepper?![]()
There isn't a nut on this planet that I can't handle.
An Imperial gallon of water weighs exactly 10 pounds. Metric enough for ya?Entire Metric system is based on the properties of water. ... How much does a gallon of water or gasoline weigh? Never learned that in school or even have the ability to hazard an educated guess....
