DLC is Diamond Like Coating, TiN is just a bonded to the metal. It doesn't "scratch" it just wears. I have had a lot of trouble scratching my Millies DLC coating.
Black-T is not durable. It's often used on pistols, and is easily scratched by a kydex holster.
DLC is pretty good, i have it on a couple of MOD's i have but it will scuff/scratch, just not as easy as some coatings will.
but then of course any and all coatings will scuff/scratch with use.
Anything will scratch. Coatings are all different. In Al applications, you can find that Type II anodizing will produce a wonderful array of colors, but it will scratch and wear off. Type III hard anodizing will maybe chip off of areas of high wear or use, but those chips don't spread like a coating. The coating isn't weaker because of the chips. I think DLC compares to Type III because it maybe be removed, but it doesn't really wear and fade like TiN.
With DLC/Boron Carbide/TiN there is definately a difference, I know boron carbide is harder and tougher than TiN. I can't remember what DLC was exactly, for some reason I want to say it's just a trademark for Boron Carbide. They're all way harder than most anything that could scratch them in consumer knife applications, for drill bits and industrial cutting tools there would likely be a noticable advantage to BC. With knife coatings there will be a much bigger difference due to substrate finish and the expertise used to apply the coatings.
