the most modern steel
not exatcly the density of the steel aside from temperature changes can not change i only included that bit because the powdered steel is obviously not a dense as regular steel but after being compacted it is depending on alloy content about 7.9 g/cm3 or the same as it would be for a conventionally produced steel.
grains: steel is actually composed of Crysteline graines, of pearlite, martensite, or austenite (pearlite is the soft anealled state, austenite is the state steel exist in above the critical point (temp of transition) about 1400F-1500F, martensite is the strong hard condition obtained after quenching) imbeetween the grains is ferrite, or cementite, whith are not as strong hence large grains=big "fualt lines"
It still has a long way to go, so this might be more of a "material of the future" or something, but amorphous metal does some really interesting things. Doesn't work so hot in knives...yet. But if they can figure out a way to make it work it'll be something out of a sci-fi movie. The brand name producer of it is Liquid Metal.
thank you that seems really intresting i shall try to include it in my essay as a future thing:D
thats really neat I had heard about it but never really looked into it. can you still produce high alloys contents
In 2004, two groups succeeded in producing bulk amorphous steel, one at Oak Ridge National Laboratory, the other at University of Virginia. The Oak Ridge group refers to their product as "glassy steel". The product is non-magnetic at room temperature and significantly stronger than conventional steel, though a long research and development process remains before the introduction of the material into public or military use.[3][4]
this is off of wikipedia
it indicates that the steel is non-magnetic which probably means that it is Austenetice, so can you heat treat it with out screwing up the structure, does it work for martensite or can you just temper the Austenetic steel at very high temps for long periods of time to gain a martensitic structure, with out any deletarious effects
I spelled it wrong by about 50 characters but whatever. it is the steel in a state in which the Chrystals are Austenite as briefly explained above.
basically when its really hot (above 1400F) the steel changes to austenite, if you cool it very very very fast as proposed with liquid metal technology the Austenite does not have time to transform to martensite, then pearlite, and therfore stays as austenite which is non magnetic
oh gotchya
These "glassy steels" are amorphous, and by definition have no crystal structure. They are indeed like a glass in that the atoms are not arranged in any pattern. Austenite is a crystal structure of steel, and so the glassy steels cannot be austenite. The magnetic attraction depends on the Curie temperature. This is the temperature at which iron becomes non-magnetic. This temperature can be raised or lowered by adding different alloying elements, like nickel or manganese, both of which lower the Curie temperature. I imagine these glassy steels are quite complicated with a lot of alloying elements added, which has pushed the Curie temperature well below room temperature, as happens in 300 series stainless steels. Or, things may not line up properly on an atomic level in amorphous steel, and its like most other metals in that its not magnetic.
These glassy steels are most likely the most modern steels, since they are so new that they have not had time to become commercially viable.
Ha Me2, I was gonna post somthin about steels with super high nickle and manganese content that require Cryo treatment to become magnetic, but decided it wasnt pertanent, huh I was wrong.
Amorphous metal isn't even steel. It's a mixture of dissimilar metals that when combined in a certain way "confuses" the molecules so they can't form a crystalline structure before they solidify. Last time I checked the very best forms of it were, like, 90% platinum so it was VERY costly, but they've developed other grades of it that even use blends of copper, nickel, iron, etc. They just aren't as amazing. :)
Because it behaves like a glass, and in many ways like a plastic, it can be cast in a similar manner and even made into a metallic foam! Due to its lack of a crystal structure it does have the disadvantage of not being able to dent. Impacts cause micro-fractures that end up causing sudden total failure. This is one of the things they're working on improving. However it does make it a nearly inelastic surface which means things bounce off it like crazy. The best way of eliminating the snapping factor that they've found so far (to the best of my knowledge) is by impregnating the material with micro-"hairs" of steel. They act like horse hair in plaster -- it supports and strengthens the bond of the material.
Some of this may not be 100% accurate, though, since this is off the top of my head what I know about it.
acording to wikepedia (the most reliable source on earth:rolleyes:) they are working on a steel, but it would be weird
Scraping and pounding away at a carcass that has been dead for several hours, Homo Habilis, the first handy man as he is called scavenging what is left from a giant hyena kill 2 million years ago. Cutting, scraping, and pulling a Homo Sapiens , modern man is field dressing a antelope it has killed. They both were using something that have evolved over millions of year, Homo Habilis made and used the first know stone tools, Homo Sapiens continued to develop and change the stone tools into what we use today as knives and tools. They were made to do almost anything, be durable and last as long as possible, and the time they take to make varies with complexity.
To Start off, there are so many different modern metals used for tools and knives from high carbon like 1095 to futuristic liquid metals. Stone tools were made with brittle and readily available stones such as chert, flint, and basalt. Although they are made with so many different materials the difference in use is not as big of a difference as it would appear. Modern knives are used for almost everything from cutting, to prying, and even as a hammer. Early period stone tools have been shown to be a jack of all trades tool used for scraping, cutting, and crushing. In Late and even some Middle period stone tools were being made a specialized tools to do a specific job like many of the tools used my Homo Sapiens. It was in those periods that you saw tools and blades become separate tools. Oldowan and Acheulean stone tools were the earliest stone tools. Today we have so many like the bowie, dagger, boot knife, and hunting knife. Today makers make the knives to last a life time and took as cool as possible. Back when Homo Habilis roamed they made tools that got the job done at the time with what was around and if it lasted for multiple uses even better. The early tools were used for many different things and even today there are still knives and tools made today that can do many different uses. One of the tested and proven multiple use tools is the Rat Cutlery H.E.S.T. it has a pry bar, a blade, bottle opener, wire cutter, and even a small space that can be used to store things. Old stone tools had a cutting edge for scrapping, cutting, and prying. It also had a blunt edge that was used for crushing and breanking.
Next, The durability of the tools is now something so important. First stone tools have lasted for millions of years they have stood the test of time and they are just made of simple and common stones such as chert, flint and basalt. Modern tools are made to last with constant use and some are even made to take abuse. They use titanium alloys like Beta-c, super steels such as SGPS and INFI, high carbon steels like 1095, and so many more like cobalt alloys and liquid metals. Stone tools often broke when they hit something just as hard. Modern tools are made to take a beating and keep going even when they hit something just as hard. And compared to stone tools modern tools have a amazing durability to weight ratio.
Finally, tools take time to make some can take minutes others can take months. The first stone tools were made by finding stones that naturally had the shape they needed and used it and as time went on Homo Habilis learned how to make the stone tools by a process called knapping. Knapping is taking a core stone and tapping it with a softer stone, bone or even an antler to break of a sharp piece. One of the first steels was made in India in 300 B.C. called Wootz was used to make tools of all kinds and it was exported to the middle east and to Europe. Another method for making stone tools is pressure flaking in which the Knapper takes the stone core and puts pressure on a small area with a pointed antler, bone or another stone and it breaks of a smaller even sharper edge. One of the most modern ways of making steel is Powder Metallurgy. It is the process in which a majority of modern super steels are made. A process that is even more advance and is being perfected is Amorphous metal. It is a non magnetic metal that is being used in cell phone and computer applications today, they are in the process of trying to use it in tools. It is different because it is stronger and lighter than titanium and is processed in a similar way to plastics.
In conclusion, with technology constantly changing, metal tools are much better than old stone tools. Benjamin Franklin once said “a good knife was never made from a bad steel” I interpreted that as what it is made of is what makes the tool good. So all-in-all modern tools are better because metal tools can do most anything, they have a greater durability, and are becoming easier and less time consuming to make.
did i forget anything or should i add more?
The titanium I referenced are both special alloy versions of titanium I'm not talking about plain old 6Al4V. Check out Mission knives they have been making knives with stuff for decades and their knives have been used navy seals, marine recon and other special ops units for over ten years without one knife being broken in the field. They do require more sharpening because they're softer rc 47 but their tough as nails and absolutely positively will not RUST, unless you have some saltwater with chlorine at 500 degrees centigrade to put it in.
Beta Titanium is supposed to be good for 55RC
