These have been out a while but still new to many.
Basically an excellent work and everyday folder.
And being from the coast, one thing you learn offshore is that there is no such thing as rust and corrosion proof if made of steel...and applies equally well to effects of blood or hot salty meat juices on many decent steels.
Well, that is no longer true. These steel knives are totally rustproof in any environment in which you can survive without a space suit. Chlorinated pool water included, but not the chlorine bucket, please....absolutely zero maintenance required aside from rinsing hinge to keep free of grit.
Flat and light enough even the larger rides forgotten in front trousers pocket....total weight of BOTH is 4.4oz and i carry the 1.8oz smaller one in shirt pocket....
Edge holding on par with AUS8A while one of the tougher stainless steels on market, as you can see from bend test and outside of bend just starting to rupture, very stout main body, literally near a straight razor out of box, and a tough edge which would rather dent than break, and 57Rc, to boot....
For a coastal guy, the dream and impossible knife, including huge folder carried effortlessly and unnoticed....Spyderco Salt series....H1 nitrogen, rather than oxygen, based steel.
As an FYI, the smaller with silver blade dropped from production in favor of black blade, so on-hand stock of a dealer is all there might be....i think they all might go that route or some heavier "improved" form in future, just food for thought if interested...yellow handles still available in silver blade if you like plastic banana/bic banana yellow or need for hi-viz....absolutely will not rust, even in salt water, not any part of it.....(removed) pocket clip and barrel bolt are titanium....
The reason for the endangered species talk is that in their run of the mill lines, they have gone to metal liners under the plastic...weights also went up and also size and thickness.....these Salt series knives are about the last of the old-style knives they made right after they went from integral plastic clip to removable metal clip....new ones are covered with screws holding everything together and attaching clip....i like the simple old light knives....after trying the older style and newer, found the older the ones i would actually daily carry....the newer heavy enough and bulky enough they stayed home....
