Hmmm...........I only asked because real Arctic willow doesn't usually grow much more than 6" or so high.....
en.wikipedia.org
Whatever wood it is.. it's beautiful stuff and at 10+ years old its held up remarkably well.You sure that is arctic willow? Looks more like Goat willow. Arctic willow (Salix arctica) doesn't grow large enough to make a handle from....Goat willow, other wise known as sallow root, is pretty tough stuff.....
Back to the wood debate... I agree with A Arathol . I think we're dealing with mistranslation here, Salix arctica Arctic Willow is a shrub, ground cover item unless grown in very favourable conditions, even then it's small and an unlikely yielder of bulk material.Hmmm...........I only asked because real Arctic willow doesn't usually grow much more than 6" or so high.....
Salix arctica - Wikipedia
en.wikipedia.org
Goat willow wood may be unremarkable but Marttiini used the root as handle material for their higher end models back in the day. At the time they called it sallow root. Most of it had some remarkable figure...Back to the wood debate... I agree with A Arathol . I think we're dealing with mistranslation here, Salix arctica Arctic Willow is a shrub, ground cover item unless grown in very favourable conditions, even then it's small and an unlikely yielder of bulk material.
Salix caprea is Goat Willow or Pussy Willow a very common form in Northern climes but a rather unremarkable wood used for fuel, carving or whistles etc. Known as Raita here.
Yes it is. I wonder how that was done. You've a keen eye for detail. You always spot and mention the more nuanced features and make me look twice.That pommel is neat!
Its just a fancy endcap instead of the regular flat ones used on other Marttiini knives. Its shaped to fit the end of the handle, and attached by peening the end of the tang.Yes it is. I wonder how that was done. You've a keen eye for detail. You always spot and mention the more nuanced features and make me look twice.![]()
This one from Wood Jewel is advertised as having a stained goat willow and curly birch handle.
I suspect you are correct. I've since found a couple other similar knives with the same markings listed as Karhunkynsi Brand, but I'm not really sure if that is actually the name of the maker or the model. Roselli for instance has a model with that name.Suspect it says Karhunkynsi - 'Bearclaw'
No sure what you mean by "the original"?.....The knife above was authenticated by Marttiini as being made as a commemorative for the 1940 Helsinki Olympic Games....
The Wood Jewel blade has a hammer finish. I've seen a number of Lauri blades like that. The knives sold by Erapuu for instance have similar blades.I thought Wood Jewel used Laurin Metalli blanks but that sure doesn't look like it, nice one.
Milk plastic and non-leather from Kauhaava.
