- Jun 4, 2010
Heavyhanded, you and all the other master sharpeners are more than welcome to put in your 2 cents anytime. (In my case, you guys have put in 20 or 30 dollars worth!) I worry that some day you might get tired of trying to help me. I am a better sharpener from this thread. I redid the blackberry machete. I checked for a burr as I worked and raised only a small one. The edge preformed beautifully no damage as long as I limited myself to vines. Did not do well with half inch thick woody stems though. And it was raining a little bit when I was working. I kinda forgot to wipe the machete down so now I have some nice rust on the bevels. Whoops...
Forgot that I also changed my rake path. It did seem to help.
Am not comfortable with the master title, but definitely have plenty of opinion I'm willing to share, and am happy its helping. It's very difficult to convey a lot of these concepts in print - many don't even come across well in video.
I have experimented quite a bit with rake angles and am convinced that overall a 45* path is best for angle stability. As you begin to go more perpendicular or more parallel, it feels less stable, more prone to small wobble - might be just me...
For the machete, the paper over stone with compound is your best friend. Use two or three sheets of paper and your finest compound assuming it isn't damaged - if it is, start with the black compound and clean it up first. Use some pressure, more than you'd use on a fixed abrasive - don't be concerned with a bit of microconvexing at the edge, is a good trade-off for toughening up the apex and reducing friction going into the chop. This type of tool needn't be three finger sticky though it should shave arm hair.
The 7th video in the Washboard series shows a field method for touching up a machete - in fact the one I use for the demo was left hanging in a tree for two weeks in a canvas sheath and needed to be cleaned up just to remove the rust blossoms. Can also do this sort of tool on a bench stone working in overlapping sections, or use the method I demonstrate by wrapping sandpaper around the stone and using exactly as shown. You could use the bench stone as is, but then have issues of keeping oil on it, or using it dry and maybe plugging or glazing it, so in this instance the SiC sandpaper is ideal.
On a side note, by the end of the video you can see how much swarf is building up on the knee of my jeans, and why I always emphasize taking care of whatever you're using to grind/taking into account that removed steel and any stone debris that might form - left to its own, it will negatively effect grinding quality and in many cases actually cause harm to the abrasive surface.
Martin
