"The toughest metals for knives are busse's infi steel, cpm3v, bg42 ands30v. Of these cpm3v is supposed to be the toughest at the expense ofcorrosion resistance and needing a little more work resharpenning butwith twice as long edge retention as most other steels. Busse's infisteel, a nitrogen rich steel, is supposed to have the best tradeoff intoughness to corrosion resistance and easily sharpenning, and S30v issupposed to be a great balance as well. BG42 may be stronger than S30vas this was the steel in the older sebenza's and many complained whenReeve's switched over to s30V because s30v needs to have a lowerrockwell hardness than bg42 and many said that this is a reflection ofthe steel's relative weakness to BG42. If you buy any other steel youdo so to save money on your purchase for that is the only benefit ofthe other steels. "
Originally posted by oliverplomion
What does make INFI so much better than many other steels?![]()
damned pig latinOriginally posted by thatmguy
Oli, c'est le tout.
Originally posted by idahoskunk
damned pig latin![]()
Ohhhh....time for beer and popcorn again!Les! please don't change my rang again! pleaaaaaaaaaase...
Originally posted by Andrew Lynch
Forgive me, but I just couldn't hold my tongue. I'm not sure where this quote originally came from, but I would not go by it. For one thing, the toughest knife metals CERTAINLY DO NOT INCLUDE STAINLESS STEELS! I'm sorry, lost it there for a minute. Also, the list is far longer than 3V and INFI....5160, L6, and S7 come to mind for example. Don't get me wrong, there is some merit to the quote, but I don't want to give a newbie a false metallurgic foundation.
Originally posted by Evolute
Quote from Jerry Busse: "As for INFI and temperature extremes, it is amazing. INFI is tempered at nearly 950 degrees. It does not begin to lose any significant hardness until it is held above 1050 degrees for a considerable amount of time. I have to believe that it would need to be extremely mishandled in order to do any noticeable damage.
Most of the simpler high carbon steels (of which INFI is NOT a member) can be drawn down in temper in a matter of seconds if the temperature hits above 500 - 800 degrees. Along the thin edge of a knife, a buffer or dremel can produce this level of heat and can cause serious damage if not executed by a professional. Always check the grade of steel and heat-treat specs. before assassinating it with the dremel tool Uncle Leo gave you for Christmas. Always keep the steel cool to the touch and you should be fine."
More INFI INFO coming, soon.
--Mike
