One thing that drives me insane about Scandi knives are when the maker cannot get the grind right. Scandi grinds are supposed to be zero ground. Not convexed slightly and not have a micro bevel. Many makers can't get a scandi sharp quickly so they cheat with micro bevel - or they don't know how to do a proper zero grind - so they convex the edge slightly. The Spyderco, even though it was said to be a zero grind was actually slightly convex ground knife.
TF
Tal,
You seem to be quite certain in your pronouncement that scandis are supposed to be zero ground. Can you tell me how you came to this conclusion so authoritatively? And does it apply specifically to Finnish puukkos?
I'm not being contrary. I ask because I have an outstanding puukko, made by Joonas Kallioniemi, that has a microbevel. I've corresponded with him pretty extensively about sharpening and the proper edge for a puukko, and he says that a microbevel is traditionally added for durability. I'm inclined to believe him because bladesmithing is a purview of the Finnish Ministry of Education. Joonas learned his craft at the Finnish equivalent of a vocational school. I'm sure his ideas on blade and edge geometry were taught according to established criteria. And since his knifemaking skills are at a high level, I know he doesn't sharpen his knives with a microbevel because it's easier. So since he says to use a microbevel, I definitely listen.
This doesnt' really apply to the micro bevel, but might supply a different perspective on the convex thing.
Just so that you see all sides of this, I think some makers are not aware of what is going on. I will explain what I mean.
Let’s assume the grind is even to the center line. If it is not, you are screwed right off the bat
Next, is the finish level. The belts used on knife making grinders are some kind of backing (with varying levels of stiffness) and some sort of abrasive. The coarser the abrisve, the larger the chunks of stuff attached to the belt. When you are at fairly course grits, there really is no worry of anything bad happening.
As you get finer and finer grits, the abrasive gets smaller, and the cutting edge is now getting closer and closer to the actual material of the belt. There is a point (I know where it is at for me) when you are playing with fire. Go too fine, and you risk cutting the belt, having it zing across the room and scare the crap out of you, at the same time, putting a nice gouge in your edge. Or so I have heard……
There is all sorts of pressure to get the edge to a finer finish. Knowing that you can not take it any further with traditional abrasives. Most makers could not charge enough for a hand applied mirror finish, and I can’t blame them there. So, I have seen others look to other means…..mostly cork belts. These belts have what look like large chunks of abrasive material on them, but it is cork with abrasive material applied.
They work great, and they can be used without fear to a very fine grit. But here is the rub. Cork is deformable. Use them more than a touch, and things will end up not flat. Most makers don’t understand that. They say the platen is perfeclty flat, and so is the belt. Obviously they are missing the fact that cork is deformable and they putting a pressure gradient across its surface.
So, if you stick with a bit coarser finish, flatness is much easier to achieve. But then all sorts of other things creep in. How do you explain “less finisihed” is better? Shiny mirror edges look better in pictures, or perhaps that is “what the customer wants” even though they may not understand the trade offs they are getting. Or perphaps the maker does not understand what is happening with cork belts.
All I am saying is that a maker may be trying to do something good, and not realizing that there is a down side. I think that difference between a maker that never gets out of his shop and has his customers do his testing, versus someone who makes them because they use them themselves.
I am curious what others think about all this surface finish stuff.
B
im on the same road right now lol. CLW how do you like the Skookum? i have one on the way should be here tommorow from Rod:thumbup:
