The 'slicer beast' - let's cut some steel bolts and some concrete, why not... :D (SOLD)
BogdanS
Feedback: +54 / =0 / -0
Hello my dear friends,
Thanks Good God today i was able to finish a project i was preparing for quite some time - inspired by Master knifemaker Nathan from Carothers knives to whom i thank for inspiration, i tried my limits into heat treatment and grinding geometry and i am very happy that it was a real success :)
The objective was to make a knife that can cut through steel bolts with zero edge damage and that can withstand cutting through a high strength compacted concrete construction block without damage beyond the micro bevel, without severe chipping or cracking and with the knife still being usable.
So here we are with the 'pocket beast's big brother, the 'slicer beast' the second 'specimen' of this series with a blade made out of Wolfram Special high carbon steel, hardened to app 64 HRC, with a full flat grind and a 20 degree second bevel (quite a fine angle and thin edge considering also the only 0.078" thickness of the stock). The handle is made using Meteorite G10 and the fittings are brass and stainless steel bolts. The scales are removable.
It comes with a thick kydex pocket sheath.
Please do excuse the vid exposure/quality but i haven't seen that the focus is too high and it was also a real challenge to macro shot the bevel (never knew how this is done right :)) but it can be clearly seen that after the bolt cutting the edge had absolutely zero damage and that after the concrete block cut it only had minor chipping way below the second bevel line (i was able to get it back to razor sharp in 3 minutes on a work sharp system.
The blade is app 4" with an overall of app 8".
The price for this slicer beast is only 175 usd.
All the best, God bless,
Bogdan
Dear Bogdan,
I would like to purchase this one as well if it is still available.
Regards,
Kevin
Dear Bogdan,
Regards,
Kevin
kevindarryllee@gmail.com
Thanks a lot my dear friend! It is yours too and may it serve you well and make you proud over the years ;)
This one is super light and cuts like a laser, you will enjoy it, plus the combat look makes it an eye catcher :D
Email was sent with all needed details and the knives will be shipped with next week's batch but we will of course keep in touch brother!
Bogdan
Smiticus Smiticus - i foresee you in the same position for the next round dear friend ;)
Sam Boswell Sam Boswell - ill tag you once the next one will be ready in the next few days my dear friend - thank you very much!
Bogdan
