The Strop Bat from JRE.
those look like some quality clubs there...
the main issue with multi-sided strops is that you need to make sure you are always working on a clean surface. otherwise, they seem like a good way to keep everything in one place.
those look well done, nicely and evenly loaded to boot :thumbup:
i bought the BRKT compound from knivesshipfree.com. before that, i mainly used gray tripoli compound to remove a burr with. the BRKT compound cuts faster, and i like it alot.
you can reload whenever the compound starts getting slick with removed metal. for me, this is usually after about 5 blades. the surface area of the strop impacts this though, so your strop might be different...
