View attachment 1380904 View attachment 1380905 View attachment 1380906 View attachment 1380907 View attachment 1380908 View attachment 1380909 There was a minor flap this week over the quick sell out of the BOTM knife, a take apart Aluminum 112. Many question were asked about the construction of this knife and also about the take apart 186.
The new 112 is probably similar to the 110 Aluminum Club Knife. The Aluminum knife is held together at the rocker pivot by a rivet. This rivet replaces the bushing and screw or pin normally located here. It is hidden by the scales.
The front of the knife is held together by a T-nut and a screw. The T-nut is actually the pivot post for the blade. Since there is no bushing, the pivot set can squeeze the blade. So a little blue Loctite is required to hold the pivot adjustment. The head of the T-nut is octagonal and sits in an octagonal recess. This immobilizes the T-nut when adjusting the pivot.
The rear of the knife is held together by two T-nuts which are slabbed (D in cross section) to prevent them from turning. The spring holder has D shaped holes to immobilize the T-nuts.
The 186 has 4 tapped (#5X40TPI) holes in the right handle. Various length #5X40TPI cap screws are used to hold the knife together depending on the use of the disassembly tool and/or the belt clip.
The blade and the rocker have identical bushings which are squeezed between the handles when the screws are tightened (no adjustment). The spring holder is likewise clamped between the handle slabs when the screws are tightened.
