DeadboxHero
- Mar 22, 2014
Yes, I'll write it out. It just takes longer then the video format so it will just be a bit.
It didn't sound metal, but it is full of water and stuff, and on a YouTube video. Regardless, a deformed edge is an indication of insufficient strength/hardness keeping in mind this is only the first stage.
That would be badassWhat if some of the blades were heat treated by @bluntcut ? Would the outcome change?
Thanks Josey, great ideasMe2 does make a good point; one that initially escaped me. The test really showed that Elmax was the strongest of the three blades because it had less deformation (auto correct said defamation) of the edge. You'd expect that result because the Elmax is a bit harder than the others, and strength (resistance to bending, rolling and deformation) is a proxy for hardness.
What you're looking for is resistance to chipping or breaking (toughness). You might look at the edge under high magnification and see if there are any chips. Sometimes, small chips can look like dents to the naked eye.
Because this is such a cool experiment and one that Shawn had to put a lot of time and money into, it's worth it to test it carefully.
I'd can the light taps against the metal pan. They're not a bad informal test, but it could be better. For example, you could tape a nail to a long board that pivots on the opposite end. By adding weight and height to the drop, you could standardize the test, and you could work up to higher loads (heavier, higher drops) without having to destroy the knives. Just make sure the edge is hit at 90 degrees by each blow. You could also add a 45-degree test to see how the edge holds up to lateral stressing.
All you need to demonstrate is that chipping begins at a certain point for each alloy. In the end, you could easily sharpen out the damage, and send the knives out to a wear-resistance tester for cut testing. Then we'd get fuller look at these alloys.
Regardless, this is awesome stuff. Thanks to Shawn for taking the time and thought to do it. Three cheers.
There are a few pieces of equipment I'd like to have such as a USB microscope and a dial scale to measure how much force is need to chip the edge with transverse pressure on a nail.
But I don't have the money. Hell I'd love to test what ever comes to mind but I can't.
That would be sweet for this project, yea man, team effort!Hey Shawn -- I have a new Dino-Lite digital microscope and stand. It's the AM3111T. Haven't even opened the box yet.
I could loan it to you if you want. Being able to see exactly what's going on with the edge apexes would help your tests a lot.
What you're looking for is resistance to chipping or breaking (toughness)...
{snip}
...All you need to demonstrate is that chipping begins at a certain point for each alloy...
