The Trisul: Covert Bodyguard
Steely_Gunz
Got the Khukuri fevah
Moderator
As I was going through my trunk o' knives the other night, I came upon one that I hadn't handled in a few months. I was looking for something to wear at my side during these chillier months that might serve as a bit of a back up blade to a firearm. I know it sounds a bit paranoid, but I just feel BETTER having a knife on me for protection. I've never needed one, but handling blades as much as I do I just feel more at ease knowing I have something utterly familiar available at a moment notice.
At any rate, I rediscovered a Trisul that I had left half modded from several months ago before I moved. Yangdu had this one made for me at my request back in 2008 give or take. It's 14" long, probably 13oz, and has a razor tip that could pierce a rhinos hide. It is designed to be a pure fighting/defense knife. The grips on a regular Trisul come fairly blocky and boxy and lend themselves to either a straight up an down tip up or tip down hammer grip. This one was no exception. Other than that, it was perfect:)
Soon after, however, my place of business had a fire. Some of the heat and smoke dried out the horn slabs and they cracked badly. At that time I decided to mod the Trisul more to my hand's liking. I got as far as prying off the old slabs and trying to wrap it in para-cord. I didn't like the spongy feel. I dabbled with leather slabs that worked OK but weren't perfect. I went ahead and reshaped the grip from a block and gave it more of a palm swell in the middle and ground the corner round on the backside to give it more familiar handle shape. Around that time I put some things in storage and got ready to move.
Flash forward to today::)
I finished cobbling together the reverse draw sheath I had started for it some time back. Nothing fancy or flashy, but this is a knife that isn't SUPPOSED to be seen unless it's needed.
I also solved my leather slab grip issues. I reglued them, re pinned them with rivets, and finally wrapped the whole thing thing in a layer of waxed nylon leather stitching thread. It plumped up the grip just enough make it filling and gave it enough purchase to really tack it to my hand. The reverse draw works well with the rounded part of the grip. A quick yank up and the Trisul is either in hand ready for a downward strike or elbow driven slash OR can be folded back against my forearm for a more covert hold.
It really is a remarkably quick knife to get into action. Much like a Gerber Mk series, an M-3 Trench Knife, or the iconic Fairbairn Sykes commando dagger, the Trisul is a purpose driven tool. However, being that my wife and daughter and I take a lot of walks to the river I have been feeling a little bare not sporting something light and fast to get into action. The people in my town are wonderful. Most of their dogs are as well...most of them. I still feel a little more at ease knowing I have a good piece of Nepali steel on my hip just in case:)
I really do love this design. I am anxious to one day get my hands on a sample of Howard's Liberty series. A thin Bagwell-esque fighting blade never goes out of style:)
Hadn't seen one of those before. Like a crossada without the wildly optimistic side quillions. Waxed cord is one of my favorite feeling grips- I tend to stabilize it with cyanoacrylate or epoxy then wax the whole grip.
That looks like it might like this style wrap-stripped 550 cord and system 3 epoxy:
It's one layer o stripped cord wrapped aroun the grip area, then the second repeating wrap on top.
Cord? Cool! On the pic it looks like leather!
Would leather work or will it expand to much when wrapped tight and needs to be retightened often?
If you do leather and then either cyanoacrylate or epoxy soak, you'll need to chisel it off.
(I goofed and did the wrong color for a guy teo years ago- just ran the bandsaw along the tang...)
Thank you.
That sounds pretty stable :D
Would you soak the whole handle in epoxy or just soak the leather in it right before wrapping?
Take an acid brush (the cheap sheet metal handle ones they sell with plumbing supplies) and brush the epoxy on after it's wrapped. Make sure it's system 3 or westsystem- it's thin and soaks into the cord.
Superglue you just get 3-4 tubes and wet the whole handle wrap.
Here's a pic of the one I had, emphasis on the HAD. I still kind of miss it just cause it was different.
What you mean had Bawanna!!! I should of had dibs on it :sorrow::sorrow:
Sorry, Pugs. I begged and begged, and gave Bawanna a pretty decent trade for it. I'm a big Sher fan, and this one really called to me.
Dang David, well at least I know its in good hands and in a happy place.
Reminds me of this little guy- once I fixed the heat treat warp in the blade it's one of my favorite vintage fighters.
It is-Batangueño puñal. The grind is phenomenal-convex zero edge from the ridge line, done on some kind of wheel grinder. You can see where the guy rocked the blade to get the convex. Nicely hardened too- had to put heat sink paste on the ricasso and edge and heat the spine to 350 or so to knock the warp out of it (which drives me nuts, when blades warp in heat treat and nobody fixes it...it's nicely through hardened, and TOUGH. I had to hit it pretty hard to get it straight.
Now that it's fixed it's one of my favorite EDC interpersonal crisis management knives.
I like my Trisul, which I have absolutely no use for! For some reason it is my Son's favorite HI. (Second is a 30" sirupati that he used to hack down a big bush when he was little). He always holds it up to the light and says "Excalibur" although I say "I do not think that word means what you think it means".
It does seem like a wicked fighting dagger, although mine is extremely dull. I am not good enough at sharpening to risk the tip while trying to get some kind of an edge on it.
