- Nov 1, 2000
My working knife is the Gerber Paracord, personally i'm a spyderco fan, but can't get it over my heart to abuse my folders on board, so a fixed blade is the better option for me. Tried some, but the paracord has good grip in all conditions, to bad it is not so good in holding a sharp edge for long.
Btw, i am a maritime officer on a anchor handling tug supply vessel.
So a few things I took note to: First, and unfortunately for you, the Gerber is made from 5cr15mov, a very entry level knife Steel, similar to Buck 420hc or Case "trusharp" on paper, but without the proven heat treat of those companies and with an inferior warranty behind their product creating less of a demand for tight tolerances, the Gerber is flat out junk for a work knife that needs to hold an edge.
I also realized you said you can't bring yourself to "abuse" your folders (spyderco's), hinting at 2 things, A) you're knives you use onboard see very tough use (abuse), which makes sense as tug work is hard work, and B) you may not be inclined to "abuse" an expensive fixed blade either... Considering you can't have a work knife onboard a sea vessel, that you have reservations about using, (rough seas and tangled riggings, could spell disaster, and hesitation Is not an option), so that means the David Boye options are not an option, as they cost a bit, and may even strike out the Spyderco Aqua Salt option in H1 Steel, though they can be found for just about $100 (u.s.)
I get it, I lost a $100 Griptilian into the drink once when I was a dock builder, and never carried a knife worth more then $50 onto the barge again.
Even though the cobalt and h1 Steel are impervious to rust, as it has been pointed out, any "stainless" Steel will resist rust, and with proper care should never rust, but, proper care is a must, as with seawater, all it takes is a day or two in some cases of "whoops I forgot" and spots can start forming especially on the edge, another thing I know all too well after forgetting a knife onboard the barge for a couple days due to weather, covered, and returning to find rust forming... Also while all stainless will resist rust, some better then others, as a hard use knife (as you implied, even "abuse" level), some are not very "tough" and tend to be more prone to chipping and breaking, which the higher risk if catastrophic failure is not an option you'd want to risk at sea...
440c, n695, n680, n690, vg10, 154cm, and even 12c27 are all steels that properly done have a good reputation of balanced properties between good corrosion resistence, AND good toughness, while holding an edge respectably, (and in many cases can be had at reasonable prices)
Fox Knives makes some nice affordable options in n690 and 12c27 in their European Hunter line1502-OL and the 620/13 with a stacked leather handle. Or the compso fx-304 with g10.
Böker's Plus/Arbolito lines make some nice affordable options in 440c and n695, like the Krein Bulldog or Dano
Real Steel Observer is an attractive option in 440c with a textured g10 handle... (I actually think I might even buy one of these soon).
But if you really do like the "feel" of your paracord wrapped Gerber handle, I can't recommend more strongly a stainless ESEE Izula and wrap the handle yourself, or the Böker Plus Prime prewrapped... Both 440c, the ESEE will be about a half inch shorter in the blade and cutting edge then your Gerber, but considerably lighter, the Prime will be much closer in size as your Gerber, but on steroids, thicker, and noticeably heavier.
Also, as many times before, I'd say get a stainless Mora, the santoprene handle provides good grip even when wet, and for cost, can't be beat.
I was a shipscarpenter in the Swedish Navy and I served onboard a Mineship.
This one: HMS Älvsborg
[/url] © Folke Österman[/IMG]![]()
During my servicetime,I never saw any fixed knives except for a few Mora 511's.
One of them was in my toolbox and I used it frequently as a carpenter.
The Bosun had one for ropework.
If it would be today, I would bring a Leatherman Charge Multi-Tool and a Mora Pro S.
Regards
Mikael
David Boye BDC (cobalt) knives...
Or one of the Spyderco salt's in H1 Steel
Either one won't rust...
one of my best friends is joining the coast guard, an I plan on gifting him a spyderco tusk once he finishes basic
I've hear that a rigging knife is most useful for sailors.
[not mine. example image]
I wonder if that is firstly true; and secondly if it's the same for boaters. Or if there are substantially different enough needs that it has to be another type.
