I agree with this. I have worked my way up from no tester through 3 testers now and i am so glad I did. one thing i have noticed is if your after consistency then your hardness tester MUST apply the 150kg load at a consistent speed. My wilson has dash pot that controls that. the standard is 4-5sec and i found if your over or under this you can and most likely will get a different number. I'm not quite sure how the grizzly works so i cant say it has this or not. but one thing that stands out as a minor warning to me is having to calibrate it. Hardness testers should not need to be constantly checked and adjusted. My rockwell spring powered version did but that's understandable because its powered by a spring. A dead weight tester should be set, X weight on a 120deg diamond point and it reads the difference in depth from the 10kg preload to the 150kg major load.
When I first got my wilson it did not have weights. I went through it and cleaned everything and built a weight. My research said 25:1 ratio for weights so 150kg is 6,000 grams. I made a 6,000 gram hanging weight out of bronze. I made it a tad light around 5,900g so i could bump it up with a secondary weight. Well it was exactly 2rc low consistently. Im scratching my head thinking something else was wrong and went through everything agian. everything looked good. Then i came across a few posts on another forum where someone had to build weights. people said the extra weights where 25:1 but the main weight and hanger where less as thats whats adjusted at the factory to get it reading properly. So the 40kg and 50kg weight are indeed 25:1 but the 60kg was actually around 1800g. So i went back to the shop and cut 500g off the base of my weight which is alot of material, 500g is 1.1 POUNDS. I came back in and installed the weight and hot damn it was perfect. I have a real nice test block from wilson that's 60.5 +- .5. So what im getting at is it took being off by over a pound of weight to drop the hardness 2rc. These machines are simple and should be 100% repeatable.
Not all portable testers are rebound testers. The biggest issue with rebound testers is they generally require quite a bit of material mass to be tested.Why not use portable / rebound tipe of tester ?? Price is affordable ? My friend have three serious tester but in same place he use this hand held tester.......it is fast and precisely .
Well , I just make a call.............they require lot of mass , far more then biggest knifeNot all portable testers are rebound testers. The biggest issue with rebound testers is they generally require quite a bit of material mass to be tested.
Quality checks are not value added steps. You've framed your question as though guaranteeing that what you say you're selling is actually what you're selling should cost the customer more. Does that make sense?
The payback with a hardness tester is in your reputation for consistent quality.
