The VBCAK: The Yardwork Commando Belt Knife
Steely_Gunz
Got the Khukuri fevah
Moderator
The bell on my office door jangled as the cowbell hanging off the push bar clanged against the metal frame. By the time I got up from my desk, like a ninja, the lady who delivers my mail had come and gone. The only evidence of her presence was a pile of junk mail fliers, some bills, and the always pulse-quickening triangular box:D
Inside was one of the new Villager Baby Chiruwa Ang Kholas:)
I was elated when I saw it. It really bridges the gap between the tiny KK and the 12" khuks. While not a powerhouse chopper, obviously, it is a robust knife ready for the most rough and tumble chores. Actually, that's exactly what I have in mind for it. I envision this as my new go-to yard work knife.
As a guy in a seasonal business, my time to spend in the yard is limited. All of my work is done at a breakneck pace on Sunday afternoons. On top of all of this, our new homestead not only has a larger yard but also needs more than a pinch of TLC. What I need is a tool always on my belt that can cut open mulch bags, snap cut small branches on my hedges, poke around in the dirt to find old dead root balls, cut weed barrier, etc. Actually, before it was stolen, this is exactly what my 12" Pen Knife was used for. But to be honest, it was always a tad big for the job.
The VBCAK is a perfect candidate. It's incredibly well constructed, has a long handle in relation to the blade so that you can grip it a multiple of different ways, and its less-than-high-gloss finish means that I'll actually use it instead of fretting about scratches. I see it as a knife I can always have stuffed in my belt for the jobs my KLVUK is too big to handle.
Here are a few specs:
OAL: just a touch over 9 3/4"
Blade Length: 5 1/4" with a cutting edge of about 4.5" in front of the cho
Useable handle length: 5". You really have a lot of ways to get some purchase on this knife since you can choke up to the cho comfortably.
Spine thickness: 5/16
This little blade only comes in around 9oz but it feels so solid, you would swear it's 12 or 13oz. However, the balance point is right at the blade/bolster junction. If you choke up on the knife, it disappears in your hand. It almost feels like you're handling a Mora.
The edge is very sharp. Mine actually came with just a slight bit of a flat spot on the edge that wouldn't have bothered me, but I wanted to take the edge to a very sharp but durable convex edge. In the process of using a sanding sponge to strop a basic edge, I scratched off some of the black scale. This was a non-issue as it was going to get scratched up doing yard work...but I took the opportunity to just buff off most of the scale and give it a fast phosphoric acid bath to gray up the blade a bit. There are a lot of really cool little hammer marks that really pop in the light.
The only downside I see to this cute lil bugger is that while the scabbard is top notch, the frog doesn't balance it well enough. It's pretty floppy. An easy peasy modification strap that would simply snap around the handle to secure it to the frog would work. Instead, I have elected to just remove the frog and stuff the VBCAK in my belt sash-style. The scabbard is just loose enough at the throat that I can draw the blade with a quick tug while still keeping everything else in place yet holds firmly enough that even bending forward won't cause the blade to want to slide forward. It rides perfectly there at about a 60 degree angle so that the chape doesn't grind into my thigh when I squat down, and the handle is long enough to get to at pretty any direction if I need it on a whim.
It's an incredibly handle little knife:) I'll try to take a picture or two this weekend when I give it its first big work out:)
As always, a huge thank you to Yangdu and the kamis. It's an honest to goodness work knife that will handle anything that I will be able to throw at it. :)
Awesome write-up, Jake. Those baby CAKs look really cool and useful. Hopefully there will be more of them in the future!
Great writeup Steely! Always love to hear your reviews and glad you got something to replace your Pen! I havent tried mine on the belt yet but it does fit in the front pocket nicely with the handle sticking out ready to be snagged! These are keepers!
I got one more cupcake left, I might give the Baby CAK a taste of sugar tonight. I think it's more than up to the task. I should have used it the other day since it arrived that same day but I happened to have the Chitlangi at hand. Run what ya brung ya know?
Yeah you wouldnt want to run out of edge halfway thru the cupcake:eek: Did ya lick them fullers clean when you got done?
And here I was feeling all special and stuff because I managed to snag one of these, now I find they are all over the place...And quite rightly so. I agree with everything said about these, they are cute, but that certainly does not make them ineffective. I have found a dozen or more uses for mine already and I have only had it's perfect sized little handle in my hand a day and a half now and that includes opening another triangle box. I haven't wrapped it in vinegar wraps yet, but that is on the schedule for a time when I can actually put it down for longer than 20 minutes without feeling like I need to pick it up again :D
I have been looking at the process for putting a convex edge on a couple of blades and think I understand how to get there now, but I think I won't start with this one. I would hate to mess up. Will try with a couple of lesser blades first then if I get good results this will probably be the first of my good work tools to be done.
Bawanna, that video would not have been half as good with a Baby CAK as it was with the big Chitlanigi. Glad you used that for the video. Made it much better having a dramatic bit of overkill.
There may be many of these around, never know what Auntie has on hand but I think you got the prettiest one of the bunch that I've seen so far. The highly figured nice wood one. I know Snow Wolf got one, didn't see a picture of his yet.
I know mine and Ndogs (saw his pictures) are like identical twins, I sometimes think me and Ndog are identical twins.
LoL, No worry, I think EVERYONE is going to want one of these. They are just the perfect size for almost any everyday type task. I was just amazed that the first one I saw I grabbed and now within a day of me getting that they are all over. I think poor Auntie must have been inundated with emails asking for one. Definately a good thing.
As for you and Ndog, Well I know there is a lot of similarity but there are a few distinct personality differences too. A good thing. I don't think the world is ready for 2 SHavrus but I am certain the world wouldn't survive 2 Bawannas
While I'm hurt, I've been told that many many times before. I told people in the past they broke the mold when they made me, every single one of em said that there ain't nobody would make a mold like that on purpose and if they did it by accident they most assuredly destroyed it in multiple ways to assure it was never used again.
HURT!?!? In my opinion being a 1 of a kind is a compliment. LOL As for the mold. Well in this state if you stand outdoors long enough, you will start growing mold so... Oh wait wasn't that what you meant? Yep definately an original not a duplicate...
Bawanna you are one of a kind! ..and a kind one:thumbup:Thats all good! We do seem to have many twin blades tho dont we? 25" Siru, Micro Bowie, BCAK, KLVUK, Gurkha Army Khuk, M1 Bayo...and prolly more... You do need a Giant CB!
These really are handy little blades. I used it to cut a bunch of tie down rope on my uncle's truck last night. It just blasted through it using a pull cut.
I'm actually planning on sharpening this one a little different. I usually concentrate my finer edge to the tip and sweet spot and just let the recurve be. However with the use this knife is going to see, I'm thinking a chunky semi sharp tip and sweet spot (not razor shaving sharp) and keeping a finely honed recurve. My theory is that the tip and primary edge is going to do the bashing, poking, and digging. The recurve should be fairly sheltered and can do finer work like cutting rope/twine and cleanly pruning back plants.
Hopefully I can get a pic or two of it in action. I'm working from around 8 to 8 6-7 days a week these days with my first full day off being Easter:p
That does make a lot of sense for the way I am finding mine is being used Steely. You are absolutely planning the same style of use of yours as I think I will use mine. The tip through the belly I will probably keep reasonably sharp but for more prodding, digging, hacking type actions. Then start at the recurve for the razor sharp finer cutting motions. Yep, almost exactly the way I seem to be using mine too, and I have found the recurve makes a really nice draw knife as well. Just have to be careful making sure to grab the spine of the tip and keep your fingers off the edge, LOL it IS still very sharp there.
Guys, I need some advice. I was looking at the side of my little beauty and I noticed that under the scale on the side of the blade there is what appears to be <gasp> RUST!! NO-O-O-O-O!!!
So, I was not planning on removing the forgescale, but it looks like I might not have a choice? I guess I am going to have to wrap it up in some vinegar wrapped paper towels? or is there some choice where I can keep the blackened sides and still kill the rust?
